Boston GT 50 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 15th September 2012, 02:18 PM   #1
Default Boston GT 50
Hi all
This amp doest not power on.Safe light on the front is on . Amp has no rail voltage.
Ther is no voltage on the gates of the power supply FETs.I am getting 13.02v on only
One pin of the PWM ic (will comfirm which pin later).All fuse test ok.Any pointers for this
Amp?
Old 15th September 2012, 02:22 PM   #2
If you apply both remote and B+ at the same time, the amp probably won't power up. Connect B+ and ground, then apply remote voltage.
Old 16th September 2012, 04:30 AM   #3
I tried that but no luck.I think pin 15 should have the same voltage with pin 13
But I still can not find out why voltage is not reaching that pin.I read on the dvd these
two pins are connected sometimes but on this amp they are not connected together
Sg3525
1: .00
2: .00
3: .00
4: .00
5: .00
6: .00
7: .02
8: .13
9: .21
10: .00
11: .00
12: .00
13: 15.71
14: .00
15: .11
16: .00
Lm339D
1: .27
2: .73
3: .86
4: .04
5: .00
6: 13.28
7: .86
8: .73
9:.27
10: 15.55
11: .24
12: .73
13: 6.27
14: .84
Old 16th September 2012, 08:58 AM   #4
Post photos of the area around those two ICs.
Old 18th September 2012, 06:17 PM   #5
pics
Old 18th September 2012, 09:49 PM   #6
There should be a transistor near the LM339 that has it's collector directly connected to pin 15 of the SG3525. Find it and post the voltage on all 3 pins.
Old 19th September 2012, 02:07 AM   #7
Q77 mark 4G
Pin:1 15.44
Pin:2 15.47
Pin:3 .04
Q76 also has one leg connected to pin 15
Pin:1 .04
Pin:2 .04
Pin:3 .24
Old 23rd September 2012, 08:43 PM   #8
Post the pins on the 339 that are connected to the bases of those transistors (possibly through resistors).
Old 25th September 2012, 01:53 AM   #9
The base of Q76 is connected to pin 10 through 1500 and 90 ohm resistor. The base of Q77 is not connected to
the 339.I have 339 ic in stock should I replace it?
Any one have the schematic for this amp?
Old 25th September 2012, 03:47 AM   #10
Is there a 4.7 ohm SMD resistor with one end connected to the B+ terminals and the other end connected to pin 3 of the 339?
It's likely to be relatively large. Is it within tolerance?
>> WTB: TDA1541A-S2 Taiwan made >> zeroalbedo Swap Meet 15 9th August 2012 05:34 PM
boston acoustics gt-28 protection mode ivkata Car Audio 9 3rd February 2012 08:18 PM
Boston Acoustics GT-40 mike49504 Car Audio 20 7th October 2011 03:20 PM
Boston GT-42, info needed FireII Car Audio 15 31st August 2010 01:52 AM
>>> cheap 50,000uF 60V capacitors here >>> Lubomir Swap Meet 0 1st February 2007 04:36 PM
Copyright 1999-2017 diyAudio
