Rockford Fosgate T5002 - Page 8 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Home Forums Rules Articles diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 11th October 2012, 12:46 PM   #71
diyAudio Member
Fully clockwise
R1037:0
R1040:0
R1029:0
R1030:0
R1032:0
Fully counter clockwise
R1037:0
R1040:0
R1029:0
R1030:0
R1032 :0
Theese voltages are with Q1009 and Q1010 lifted
Heres the datasheet i went by for the bias transistors
MUN2111T1 pdf, MUN2111T1 description, MUN2111T1 datasheets, MUN2111T1 view ::: ALLDATASHEET :::
If thats correct pin config heres what i get on the bias transistor
Base:0.40
Emitter:-0.43
Collector:0.47
Old 11th October 2012, 01:27 PM   #72
diyAudio Member
Does 0v mean 0.000v?
What is the DC voltage across pins 1 and 2 (from the pin configuration on the datasheet you posted) for D1006 and D1007?
Old 11th October 2012, 01:33 PM   #73
diyAudio Member
Yes it means 0.000
D1006:0.44
D1007:0.06
Old 12th October 2012, 11:35 AM   #74
diyAudio Member
Lift Q2009 and Q2010 in the other channel and confirm that you read 0.000v across all corresponding resistors in that channel and confirm that you have essentially 0v across the speaker terminals for the 2000 series channel.
Old 12th October 2012, 12:57 PM   #75
diyAudio Member
Lifted Q2009 and Q2010 and get 0.000 volts acros all the 2000 series resistors as well..
I get 0.02 volts across the speaker terminals
Old 12th October 2012, 01:49 PM   #76
diyAudio Member
At one time, the amp was burning the 604 ohm resistors. What did you do to stop that?
Old 12th October 2012, 01:58 PM   #77
diyAudio Member
I replaced the LM317 and The LM337 and it stopped burning the resistors..
The crazy thing about this amp is If i lay my finger across the board around the Q1000 all th way to Q1005 I can get the distortion to go away and output is clean
If i do the same for the 2000 series parts that channel also has clean output as soon as i remove my finger from the board the distortion comes back..
I removed all the components in that area (1000 series parts) cleaned the board and resolderd everything still distorts until i lay my finger across the board..
If i try to bridge the amp Left + right - i get very lil output almost no output at all
Old 14th October 2012, 05:09 AM   #78
diyAudio Member
I'm assuming that you tried this previously (not recently where Q1009, Q1010, D1002-2005 are supposed to be out of the board).
Old 14th October 2012, 05:55 AM   #79
diyAudio Member
correct
Old 14th October 2012, 07:20 AM   #80
diyAudio Member
I'm stumped for now. You've verified that all of the various supplies are present and it appears that you've checked all components in the channel. Generally, when both channels are affected, the problem is a power supply or control issue.
email me.
babin_perry@yahoo.com
Reply
Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 02:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 08:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 04:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 05:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 8th April 2010 12:48 AM
New To Site? Need Help?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Copyright 1999-2017 diyAudio
Content Relevant URLs by vBSEO 3.3.2
Wiki
