Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T5002
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 3rd October 2012, 04:31 AM   #61
Perry Babin is offline Perry Babin  United States
diyAudio Member
What is the DC voltage on the following resistor when the bias pot is at each extreme position?
R1037
R1040
R1029
R1030
R1032
Old 3rd October 2012, 12:47 PM   #62
S Merlington is offline S Merlington  United States
diyAudio Member
R1037:45.1
R1040:-45.5
R1029: 1 side 4.05 other side 13.44
R1030:2.95
R1032: 2.30
Old 5th October 2012, 02:08 AM   #63
diyAudio Member
I should have used 'across' instead of 'on' when I asked for the voltage on each resistor. Measure the DC voltage directly across each of those resistors.
Old 5th October 2012, 08:53 PM   #64
diyAudio Member
R1037:0
R1040:0
R1029:9.48
R1030:0.74
R1032:0.12
Old 8th October 2012, 11:21 AM   #65
diyAudio Member
Do the voltages look normal or are they way off in the post above?
Old 9th October 2012, 05:03 AM   #66
diyAudio Member
R1037:0
R1040:0
R1029:9.48
R1030:0.74
R1032:0.12
Old 9th October 2012, 10:56 AM   #67
diyAudio Member
Lift Q1009 and Q1010 and post them again.
Post the voltage at both extremes of the bias pot.
Old 10th October 2012, 01:45 PM   #68
diyAudio Member
R1037:0
R1040:0
R1029:0
R1030:0
R1032 :0
Right Channel Bias pot:0
Left Channel:1.05
Old 10th October 2012, 08:07 PM   #69
diyAudio Member
R1037:0
R1040:0
R1029:0
R1030:0
R1032 :0
Left Channel Bias Pot:1.05
On the Bias transistors here are the voltages i get
Left Channel
Base:-0.44
Collector:0.50
Emitter:-0.39
Right channel
Base:2.39
Collector:1.53
Emitter:13.12
Old 11th October 2012, 07:33 AM   #70
diyAudio Member
Lets work with the 1000 series channel for now. I need the voltage across those resistors with the bis pot fully clockwise and with the bias pot fully counter-clockwise.
Are you sure that you have the voltage/pin configuration correct for the bias transistors? The voltage shouldn't be higher on the emitter than on the collector.
Reply
Rockford Fosgate T5002Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 01:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 07:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 03:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 04:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 7th April 2010 11:48 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.00%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
