Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T5002
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 1st October 2012, 10:30 PM   #51
Perry Babin is offline Perry Babin  United States
diyAudio Member
Double-check the regulated voltage on the op-amps.
Old 2nd October 2012, 01:14 AM   #52
S Merlington is offline S Merlington  United States
diyAudio Member
Ok i got + - 13 volts on the op-amps..
The gain was turned all the way up thats why i had a square wave on pin 7
Still have very distorted output on both channel outputs..
Old 2nd October 2012, 06:36 AM   #53
diyAudio Member
Are you 100% sure that every component that you replaced was with the correct type/value?
Are you 100% sure that the connections between the bias transistors and the main board are intact?
Old 2nd October 2012, 11:43 AM   #54
diyAudio Member
Yes 100% sure every part that was replaced is the correct one And the correct value..
Yes 100% sure that the bias transistors are making contact with the main board..
Should i replace the Bias transistors to see if they are defective ?
Old 2nd October 2012, 09:21 PM   #55
diyAudio Member
Check the pots to confirm that they both have the marked resistance across their terminals and the wiper swings (measure resistance at various points in the rotation) from one outer terminal to the other.
Old 3rd October 2012, 12:01 AM   #56
diyAudio Member
Both Pots are marked 202 So guessing they are 2K pots ??
Left channel bias pot fully counter clockwise i get :0.647K ohms
With the bias pot fully clockwise i get: 8.3 ohms
Right channel fully counter clockwise i get:0.667K ohms
fully clockwise i get:8.5 ohms
Turning them at various points i get different reading so im guessing they are working like they should
Old 3rd October 2012, 12:24 AM   #57
diyAudio Member
Did the output transistors initially fail in this amp?
Old 3rd October 2012, 12:26 AM   #58
diyAudio Member
Power supply Transistors was what failed in the amp along with the gate resistors and drivers for the power supply and the Lm 317T also failed...
Outputs were never touched..
Old 3rd October 2012, 12:42 AM   #59
diyAudio Member
If you place the black probe on the source of Q1024 and the red probe on the gate of Q1024 and turn the bias up, what is the highest voltage that you read?
Old 3rd October 2012, 01:46 AM   #60
diyAudio Member
-0.49 volts is all i get no matter where i turn the bias pot the voltage never changes
Reply
Rockford Fosgate T5002Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 01:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 07:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 03:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 04:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 7th April 2010 11:48 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.00%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
