Go Back   Home > Forums > >
Home Forums Rules Articles diyAudio Store Blogs Gallery Wiki Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Rockford Fosgate T5002
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 1st October 2012, 05:31 PM   #41
Perry Babin is offline Perry Babin  United States
diyAudio Member
Q1009's collector is directly connected to Q1016s base. Why are you getting different readings?
Old 1st October 2012, 05:35 PM   #42
S Merlington is offline S Merlington  United States
diyAudio Member
Q1009 collector : held the probe on it longer voltage jump around the same as Q1016's base does
Should i try replacing Q1016 and then test voltages?
Old 1st October 2012, 05:59 PM   #43
diyAudio Member
OK replaced Q1009 and Q1016
Q1009
Collector:14.39
Base:13.70
Emitter:14.41
Q1016
Collector:44.03
Base:14.39
Emitter:13.82
If i turn the Bias pot up the voltage on thoose 2 transistors starts jumping all over the place ...
If i turn the bias pots up the current draw will not increase..
The Pots are fully counter clockwise right now
Old 1st October 2012, 08:14 PM   #44
diyAudio Member
What's the resistance between the emitter of Q1016 and the non-bridging speaker terminal?
Old 1st October 2012, 08:27 PM   #45
diyAudio Member
0.612 K ohms
Old 1st October 2012, 08:36 PM   #46
diyAudio Member
What board # is in this amp? The diagram that I have indicates that it should have 28v of rail, not 40+.
Old 1st October 2012, 09:16 PM   #47
diyAudio Member
PC-4892-A
Old 1st October 2012, 09:32 PM   #48
diyAudio Member
I think the voltage on the diagram is wrong.
When you adjust the bias and the voltage fluctuates on those two transistors, is there any significant voltage driven to the speaker terminals?
Old 1st October 2012, 09:42 PM   #49
diyAudio Member
No voltage remains the same. 0.04
Old 1st October 2012, 10:03 PM   #50
diyAudio Member
Ok for some reason Now i dont have clean audio on pin7 of U103 and also no clean audio on U203
Reply
Rockford Fosgate T5002Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 01:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 07:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 03:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 04:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 7th April 2010 11:48 PM
New To Site? Need Help?
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 15.00%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd.
Copyright ©1999-2018 diyAudio
Wiki
