Rockford Fosgate T5002 - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Home Forums Rules Articles diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 18th September 2012, 04:31 PM   #21
diyAudio Member
Just found that Q17 is shorted from legs 2 to 3
Old 18th September 2012, 04:46 PM   #22
diyAudio Member
In diode Check the LM337T out of the board measures
Legs 1-2:0.640
Legs 1-3:0.724
Legs 2-3:0.770
Probes reversed
Legs 1-2OL
Legs 1-3:OL
Legs 2-3:0.516
Does this look ok or oes it appear to be leaking between legs 2-3 ?
Old 18th September 2012, 09:42 PM   #23
diyAudio Member
This isn't a transistor and can't be checked in this way. The LM337 is an integrated circuit that likely has several dozen transistors and resistors in it. You could look up the datasheet if you're interested.
Post #20 questions?
Old 21st September 2012, 02:30 PM   #24
diyAudio Member
R63 measures:1.135 Its marked 1301
R65 measures:120.0 Its marked 1210
C35's negativee terminal reads 0.46 volts
Old 23rd September 2012, 08:51 PM   #25
diyAudio Member
1.135 what? It's rare to have a meter that will read to the thousandths of an ohm.
Old 24th September 2012, 02:05 AM   #26
diyAudio Member
Measured it again to be sure and R63 measures 1.137 on my meter
Old 30th September 2012, 06:59 AM   #27
diyAudio Member
Ok I got the amp to stop burning resistors..
Wondering what 2 diodes i lift to disable the protection in the left channel They are the 1000 series patrts?
Old 30th September 2012, 07:37 AM   #28
diyAudio Member
D1002-D1005.
Old 30th September 2012, 04:15 PM   #29
diyAudio Member
Lifted D1002 and D1005 Left channel is still very distorted ..
I have both + - rail voltage and both + - 13 volts of regulated voltages on op-amps
Any ideas what to check next?
Old 30th September 2012, 05:32 PM   #30
diyAudio Member
Ok i got both channels To produce Audio..
Problem is both channels a have very distorted output ..
I lifted D1002, D1005, D2002 and D2005
No change in the distorted output..
I cleaned all switches ...
I have Both + - rail voltages on both channel outputs also have + - 13 volts of regulated voltages on all op-amps...
Protection light is barley lit on this amp but still lit up ..
Any ideas where to check next to see if i can find the problem of the distorted output ??
Reply
Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 02:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 08:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 04:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 05:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 8th April 2010 12:48 AM
New To Site? Need Help?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Copyright 1999-2017 diyAudio
Content Relevant URLs by vBSEO 3.3.2
Wiki
