Rockford Fosgate T5002 - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Home Forums Rules Articles diyAudio Store Gallery Wiki Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Please consider donating to help us continue to serve you.
Ads on/off / Custom Title / More PMs / More album space / Advanced printing & mass image saving
Reply
Thread Tools Search this Thread
Old 18th September 2012, 12:49 PM   #11
diyAudio Member
Short Q2016's base to Q2017's base ?
Old 18th September 2012, 01:07 PM   #12
diyAudio Member
Yes.
Old 18th September 2012, 01:36 PM   #13
diyAudio Member
Shorted the bases The right channel the resistors burn up faster now..
The left channel they burnt up as well and also R1024 and R1025 also burnt up
Old 18th September 2012, 01:42 PM   #14
diyAudio Member
Lift Q2009 and Q2010.
Remove the jumper.
Replace the two 604 ohm resistors. Do the resistors burn?
Does the amp draw excessive current with the bias pot fully counter-clockwise?
Does the bias pot work normally?
Do you have any DC across the speaker terminals for this channel?
Old 18th September 2012, 02:05 PM   #15
diyAudio Member
If i lift Q2009 and Q2010 the resistors no longer burn in that channel..
With the Bias pots fully counter clockwise the amp powers up and idle's perfectly..
Bias pots are working correctly..
I have -0.70 volts measured directly across the speaker terminals for the right channel
Old 18th September 2012, 02:19 PM   #16
diyAudio Member
Do you have the 17v on Rx024 and Rx025?
Old 18th September 2012, 02:25 PM   #17
diyAudio Member
On R2024 i have 0 volts on 1 side and -13.65 volts on the other side
On R2025 i have 43.75 volts on both sides of it
Old 18th September 2012, 02:40 PM   #18
diyAudio Member
What is the DC voltage on all 3 terminals of Q17?
Old 18th September 2012, 02:49 PM   #19
diyAudio Member
Leg 1:40.4
Leg 2:30.2
Leg 3:31.1
Old 18th September 2012, 03:18 PM   #20
diyAudio Member
With the black probe on the ground terminal of the amp, what is the DC voltage on the negative terminal of C35?
Confirm that R63 and R65 are within tolerance.
Reply
Hide this!Advertise here!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rockford Fosgate T5002 mike49504 Car Audio 22 2nd February 2012 01:23 PM
Rockford Fosgate T5002 mike49504 Car Audio 8 29th January 2012 07:08 AM
Rockford Fosgate T5002 mike49504 Car Audio 3 14th June 2011 03:55 AM
rockford t5002 Bobdabuilder Car Audio 4 13th April 2010 04:02 PM
Rockford T5002 Bobdabuilder Car Audio 0 7th April 2010 11:48 PM
New To Site? Need Help?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Copyright 1999-2017 diyAudio
Content Relevant URLs by vBSEO 3.3.2
Wiki
