Go Back   Home > Forums > General Interest > Car Audio
Old 16th September 2012, 09:48 AM   #11
Mote is offline Mote  Estonia
This amp uses 2sa1015 as drivers, collector is tied to ground.
Tools: C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 16th September 2012, 10:15 AM   #12
Are you sure that those are the right transistors?
Unless this amp uses a drive circuit that's very different from most amps, that transistor should be a PNP transistor.
Does this amp use an emitter follower pair (NPN and PNP transistors) for the drivers?
Old 16th September 2012, 10:24 AM   #13
It is PNP transistor.2SA1015 is printed on the board on all 4 locations for drivers. Two have their bases connected to pin 9 of 494, two of them to pin 10 of 494.
All collectors tied to ground, emitters connect to gates of two IRFZ44N through a 100 ohm resistor.
Old 16th September 2012, 10:53 AM   #14
I misread the part number. Does the amp use any NPN drivers or does it have a diode connected across the base and emitter of the PNP driver?
If it uses a diode, what is the DC voltage on pins 11 and 12 of the 494?
Old 16th September 2012, 11:12 AM   #15
It uses a diode.
Voltage on pins 11 and 12: 9,8 and 8,9V.
Voltage across B+ and GND: 10,2V
Old 18th September 2012, 11:10 AM   #16
Why is your power supply producing only 10.2v DC?
What is the amplitude of the square wave on pins 9 and 10?
How does that compare to the voltage on the gates of the FETs?
1kw+ SMPS...blowing FETS at full voltage kvasefi Power Supplies 21 1st February 2010 11:17 PM
punch 150hd PS fets damage Car Audio 9 18th December 2009 12:54 AM
Pearl PS blowing fuses Paul Ebert Pass Labs 12 2nd June 2008 03:55 PM
power supply fets keep blowing Clipped Car Audio 23 22nd January 2006 06:48 AM
What's that sound? BOSOZ PS blowing up? lgreen Pass Labs 10 23rd October 2004 09:53 PM
Copyright ©1999-2013 diyAudio
