Kove Audio ZD2000V amplifier schematic?
Old 10th September 2012, 12:20 AM   #11
Perry Babin is offline Perry Babin  United States
Post a photo of those two ICs and the components immediately around them. It needs to be as clear as possible. Use a real digital camera if you have one.
Old 10th September 2012, 01:46 PM   #12
Briareus is offline Briareus  United States
Here are three more shots of the board. I tried to get two different angles of the chip set and then also one half of the FETs. Hopefully they are good enough was having a hard time with lighting.
Old 11th September 2012, 10:50 AM   #13
I was hoping to find a schematic diagram close to the circuit in this amp but with the voltages you posted, none that I have appear to be similar. Do you have a digital camera that will take better photos? If no one else can help, I'd need better photos, including at least one good one of the bottom of the board for the around the KA7500 and LM393.
Old 13th September 2012, 01:08 AM   #14
Had an eventfull day. Lighting cooperated so think I got some good pics. Desoldered as many resistors and diodes that I could get to and tested. Everything so far is in tolerances and diodes working properly. Got a few capacitors pulled and getting them tested tomorrow afternoon. This is really turning into an unusual error as haven't been able to find a fault yet.
The pictures are in order of placement on the board. Both top and underside. I labeled the picture overlap.
Old 13th September 2012, 07:10 AM   #15
Are there two diodes with their anodes (end without the black band) connected to pins 1 and 7 of the LM393?
If so, do the cathodes of those diodes connect to pin 1 of the KA7500?
Old 13th September 2012, 08:01 PM   #16
pin 1 of the LM393 goes to the cathode side of D31
pin 7 of the LM393 goes to R90, R115, and anode side of D21
pin 1 of the KA7500 goes to R91
R91 goes to R93 which goes to pin 4 of the KA7500
Old 14th September 2012, 01:43 PM   #17
This is going to be too time consuming to do this way since it seems to be significantly different than most of the common amps. Have you tried to get the diagram from Kove?
Old 16th September 2012, 02:03 PM   #18
Yeah the company moved to Germany. I tried the last american contact for the company but that site has been idle for years. I got a few more components tested with no new results so put everything back together and put the amp away. Got other projects to work on anyways. Thanks for the help.
Old 25th October 2012, 05:37 PM   #19
pete0068 is offline pete0068
US Amps owned them for a short while after Kove went under
Kove Audio ZD2000V amplifier schematic?Hide this!Advertise here!
Schematic: Audio Innovations, The first audio amplifier maartentje Tubes / Valves 28 12th July 2016 12:41 PM
Audio analogue puccini amplifier schematic supernet Solid State 2 27th December 2012 08:28 PM
info on 15" kove audio? xaee Subwoofers 2 6th December 2011 01:47 AM
Cambridge audio A5 integrated amplifier schematic cahillj Solid State 1 11th April 2009 01:54 AM
