Lanzar Opti Drive Plus 100
Old 15th September 2012, 03:46 PM   #31
Buickmike is offline Buickmike  United States
Alright, I got new opto couplers and still no luck. My brother in law came out to visit and has a lot of soldering experience. He cleaned up the board (and all my poor soldering). Not sure if I missed something at this point.
Old 17th September 2012, 07:21 PM   #32
1moreamp is offline 1moreamp  United States
we need to list all the voltages on each pin of the PWM control chip. Its the large one in the center of the opto's. Turn the amp on and let it go into protect and then measure each pin of the PWM chip with your black probe connected to the ground of the 12 volt supply. please list them pin for pin I.E. pin1 = Pin2 = etc...
Another option is for you to directly compare the voltages from your working amps PWM to the non working amps PWM and then just post any differences you may find.
Old 8th March 2014, 03:48 PM   #33
Wow! I put this thing off to the side, pretty much giving up on it. Then I circled back and figured it out. So I initially tested the thermistor by measuring the resistance, heating it up, and making sure that the resistance went up. Well, after tracing everything back over the last couple days and finding nothing, I ended up comparing the resistance of the thermistor on this amp to the resistance of the one on my 50. The 50 was about 50 ohms and mine was about 800. So I put a resistor across the circuit to mimick the 50 ohms and voila! It works perfect!! I am happy as a clam now. I have some sentimental attachment to this amp. It used to drive 2 Lanzar Pro Plus 12's HARD!!! That being said, I royally beat this thing back then since I was running both 4 ohm subs in parallel with the sub wave boost way up and 50hz cranked off my Kenwood 5 band EQ.
Not I need to figure out where to replace this thing. The letters on it are something like PD1 UEISK. That is not bringing up anything for me. Anyone care to help?
Old 8th March 2014, 04:05 PM   #34
Here is a pic:
Lanzar Opti Drive Plus 100Hide this!Advertise here!
Lanzar Opti Drive TMS 200 Anothertime Car Audio 13 8th March 2012 02:46 AM
Lanzar OPTI 100.2 mike49504 Car Audio 4 11th November 2010 03:48 AM
Needs specs for old lanzar opti 100 MatthewS Car Audio 3 16th April 2009 12:00 AM
DC on the speaker outputs, Lanzar Opti 100 Mike1008 Car Audio 10 1st June 2006 04:05 AM
Amplifier Lanzar opti drive 2200 Urosch Chip Amps 1 27th September 2004 11:36 PM
