diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   jl audio 500/5 gate resistors*pic* (http://www.diyaudio.com/forums/car-audio/218745-jl-audio-500-5-gate-resistors-pic.html)
DcMaN 29th August 2012 05:01 PM
1 Attachment(s)
Hello, im currently working on a jl 500/5 and 4 of the power supply fets were completely burnt/ cracked along with the gate resistors, im going to replace all the fets and gate resistors, however 3 of the 4 solder pads for the gate resistors for R802 and R805 are completely gone and i have nothing to solder to. What is the best method to repair this broken trace for this situation?
Perry Babin 30th August 2012 06:59 PM
You can use resistors with wire leads instead of SMD resistors. You can also use small wires to replace the burned/missing traces with SMD resistors.
DcMaN 30th August 2012 08:46 PM
as far as the trace goes for the top of R805, it looks like one end goes directly to the inner most leg and the center leg of the fet correct ? Also can i Solder a wire from R804 to R805 for the bottom end of the trace ? I followed the traces and it looks like they all connect together. If not where would be the best place to solder to ?
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
