Rockford Fosgate Punch 200 IX - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd September 2012, 04:04 AM   #11
The amp uses the voltage across both rails for regulation. Since there is no negative voltage, the positive rail is higher than it should be.
Are you measuring the voltage on all legs of the outputs to see if there is negative rail voltage?
If you don't have negative rail on any leg, it should be simple enough to follow the large traces to find the break.
55v on the positive regulator will probably damage it. It's only rated for about 40v.
Old 2nd September 2012, 04:11 AM   #12
Yes measuring all the legs on every output and get no negative voltage
Old 2nd September 2012, 04:32 AM   #13
Ok i found the broken connections as soon as i solderd them back together the 7915 went up in smoke..
SO the middle leg of the 7915 connects to the middle leg of the U1620R and the first leg of the 7815 connects to the middle leg of the U1620 correct ?
Old 2nd September 2012, 04:34 AM   #14
Yes.
Old 2nd September 2012, 04:40 AM   #15
SO legs 1-3 or both rectifiers in this amp show 0 ohms between them IS that normal ?
Old 2nd September 2012, 05:13 AM   #16
Yes. You're reading the resistance of the secondary windings.
Rockford Fosgate Punch 250m2 seankane Car Audio 2 1st February 2012 04:21 AM
Rockford Fosgate Punch 200.4 seankane Car Audio 33 23rd November 2011 10:39 PM
Rockford Fosgate Punch 200IX seankane Car Audio 64 12th May 2011 12:48 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 04:20 PM
Rockford Fosgate Punch 360a2 dawkins Car Audio 1 6th April 2006 05:27 PM
Copyright 1999-2017 diyAudio
