sg3525an: need help desining test circuit - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 9th October 2012, 11:10 AM   #11
The datasheet should give you a logic table for the AND gate.
Most ICs change state when the clock pulses. Instead of trying to see this with a high frequency clock, use a momentary switch to pulse the clock input. You will likely have to install a small capacitor across the switch to prevent false triggering.
Old 9th October 2012, 11:40 AM   #12
palstanturhin's Avatar
4017 is good.
CMOS version of it gives totempole output - which is good.
Check for its speed - will it be fast enough for you?
Drive an AND-gate (ex. 4081) with the output from 4017 and with the output from your 3525.
AND-gate then gives you the PWM signal you need.
Check for their speeds first!
Need help DeSiNiNg 8'' SUB box. harp mg Subwoofers 7 31st May 2011 07:36 PM
PGA 2311 Test Circuit HarryK Chip Amps 13 15th March 2011 09:42 AM
Need a circuit to noise test BJTs Henry8 Solid State 12 20th December 2010 02:01 PM
Tube aging, in-circuit test? Skorpio Tubes / Valves 5 27th September 2010 09:11 PM
sg3525an PWM chip IMPALAMAN1 Car Audio 8 3rd June 2006 01:41 AM
Copyright 1999-2017 diyAudio
