#11 |
That transistor is in parallel with other (adjacent) transistors. I'd suspect broken traces or pulled vias if it reads shorted and the others do not.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#12 |
vias?
#13 |
the 3 in that bank read 0 ohms across legs 2 and 3
#14 |
Vias are the copper feed-throughs that connect the traces on one side of the board to the traces on the other side of the board.
Are either of the other two shorted? If not, there may be an open connection between the drive circuit and the gate of the FET that was preventing the FETs from switching off.
#15 |
all 3 read shorted in circuit
#16 |
Are all 3 OK out of the circuit?
Did you check the ones on the other side? Many times, when you have parallel transistors, you can find the shorted one by measuring the resistance from the gate to the drain. The shorted one will read lower resistance than the other ones.
#17 |
the other side checks fine , here is Q203 of the bank what it reads out of circuit, will post other 2 as well
#18 |
#19 |
These are OK. If the 3rd one is similar, it's also OK.
#20 |
| Need help! Hifonics Brutus bxi 2010D 2000 Watt Amp! | ZarazuaT | Car Audio | 12 | 15th January 2013 08:09 PM |
| hifonics bxi 2000 brutus | timwebb | Car Audio | 3 | 7th May 2012 04:06 AM |
| Hifonics Brutus BXI 2008D | mike49504 | Car Audio | 13 | 17th February 2012 04:21 AM |
| Hifonics Brutus BXi 2608D | Dr Zeus | Car Audio | 6 | 16th June 2011 03:34 AM |
| Hifonics Brutus BXi 1606d parts | Bertje | Car Audio | 2 | 3rd June 2010 03:33 PM |
