Zapco Z400C4-SL... Not Again! - Page 5 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 24th September 2012, 04:00 AM   #41
90scaraudio's Avatar
Finally installed the two A06 and two A56 SMDs on the problem channel. I circled them in the pic. Also, gisewhcs, the fan needs to blow into the amp and it does speed up when the volume goes up. I made a short vid of the amp working in my car, sounds decent. Thanks for all the help everyone.
100 4306 2 - YouTube
Old 24th September 2012, 11:44 AM   #42
Originally Posted by 90scaraudio View Post
They are old and they ohm out ok but with them in circuit the amp struggles to start. Plus these boards are so fricken delicate, when I was pulling two of the caps, two of the circular feed through that sits in the hole came out. The positive rail has the main trace in one of the inner layers and that sucks to fix. The ripple with the old caps was about 30 mv, now its down to 2 or 3 mv. I may get larger value caps at a latter time.
How come the old Soundstream reference 1000s only has two 1000uf 50v caps for its rail? See pic...
I did put new Panasonic 4700uf 50v caps in and 1moreamp suggested a workaround for the pulled via. I ran a piece of 14g magnet wire over to where the pulled via was from the good via. Worked perfect.
Zapco Z400C4-SL noisegate jumperboard? gisewhcs Car Audio 1 6th January 2012 08:04 PM
Zapco Z400C4-SL missing it's fan gisewhcs Car Audio 4 10th May 2011 05:28 PM
Zapco Z400c4-SL no power supply fongman Car Audio 36 15th March 2010 07:00 PM
Zapco z400c4-vx problem shallowfu Car Audio 17 4th November 2006 05:14 PM
Zapco Z400C4-SL scott-leanne Car Audio 23 13th May 2006 08:44 PM
Copyright 1999-2017 diyAudio
