Kicker ZX300.1 going into Protect mode, I need help - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 13th August 2012, 11:58 PM   #11
Perry, I hope that these are to your liking.
Q6 removed - powers up without going into protect
Q6 replaced & Q9 removed - goes into protect mode.
I have more pictures of this board at this quality if you would like them. I can email them to you or you can download them off of my photobucket account. I have not uploaded them all yet though.
Old 14th August 2012, 12:05 AM   #12
What does the base (center leg) of Q6 go to? If it goes to a resistor, follow the circuit beyond the resistor.
Those photos are much better. I'll ask for them as needed.
Old 14th August 2012, 12:44 AM   #13
It goes through R20 and into the collector (right leg) of Q5 (2N 4403)
Old 14th August 2012, 01:09 AM   #14
Remove and check Q5 carefully. Check for leakage as well and checking for two good junctions.
Old 14th August 2012, 01:57 AM   #15
Q5 checks out OK, I could not find any leakage between any combination of legs.
The base of Q5 goes through R15 and into J36. The other end of J36 connects to the collector of Q115
Here is a picture of Q115
Old 14th August 2012, 11:03 PM   #16
With Q6 in the circuit and either of the two transistors mentioned above out of the circuit, does it power up normally?
Old 15th August 2012, 11:44 AM   #17
With Q5 out it will power up fine, I will put Q5 back in and remove Q115 and check.
Old 17th August 2012, 12:14 PM   #18
I followed your direction and kept going "down" the traces removing and testing transistors that were in line. I found a MPS A92 (Q114) that has a leak or short between the emitter and collector. I am in the process of obtaining a replacement. Once I have it back in I will test again to see if it will power up without going into protect mode.
Thanks for the help
Old 27th August 2012, 01:09 AM   #19
OK, I finally was able to free up some time and put a new transistor in. The amp powered up without going into protect mode and has output. So I put it all back together for more testing.
I currently have it hooked to be put under strain (installed in my car). So far all is well.
Thanks for the help Perry, you are a blessing.
Kicker ZX.750 Cycling in&out of protect mode shawn111493 Car Audio 26 19th June 2012 02:23 PM
Kicker 650.4 in protect torisspacedog Car Audio 13 4th May 2012 07:58 PM
kicker kx800.4 stuck in protect mode ivkata Car Audio 4 15th December 2011 01:28 AM
Amp keeps going into protect mode... legalizeeit 420 Car Audio 30 19th December 2010 09:24 PM
Mcintosh mc440m in protect mode LANNYMAN73 Car Audio 3 20th October 2010 01:22 AM
Copyright 1999-2017 diyAudio
