This Kicker kx850.2 played at a high level for an hour. The heat sink measured 110 deg.F. but the fan will not come on. I tested the fan on a 12 v power supply and it checks ok. B+ is measured from ground to the fan socket + terminal, but 0v across both terminals.
Any ideas anyone?
#2 |
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
May be that the fan is driven by a transistor or fet at a given temperature. The, some components in the sensor may be fake, for instance, a PTC, a NTC, or other thing. Also a transistor may be open circuit. Finally, may be a op amp or comparator used with a reference voltage, some of them also may be faulty.
LW1DSE |
#4 |
110°F is very cool for electronic components. Don't expect the fan to come on until the amp gets too hot to hold your hand on it. The fan runs at 2 speeds. It won't run at high speed until the amp is so hot that you can't hold your hand on the sink for more than a second.
Generally, the fan will spin up for a second when the amp is initially powered up. If it spins, everything is probably OK.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#5 |
Thanks Osvaldo for the suggestion.Perry, I heated the heatsink up to about 150 deg.F. and that fan kicked right in! Thanks again Perry.
| Kicker ZR1000 | seankane | Car Audio | 0 | 8th April 2011 10:37 PM |
| NAD 5420 CDP STA341M overheat | fastvideo | Digital Source | 12 | 8th September 2010 12:00 PM |
| 400A Overheat ?? | ct1agi | Pass Labs | 2 | 26th April 2010 07:34 PM |
| Overcurrent, overheat and overvoltage protection for TL494 | Janez | Power Supplies | 17 | 21st December 2007 02:36 PM |
| PLEASE HELP receiver overheat problem | scottb32198 | Everything Else | 4 | 17th November 2003 12:48 AM |
