diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Soundigital 8K (http://www.diyaudio.com/forums/car-audio/217481-soundigital-8k.html)
brandes.cm 7th August 2012 12:23 AM
Soundigital 8K
What is the IC located next to the IR2010's, the number is scratched off. I will post a pic in a bit.
brandes.cm 7th August 2012 09:13 PM
1 Attachment(s)
I need a resistor value also circled on the pic. Emails sent off to Jose Diaz and others, no reply yet.
brandes.cm 8th August 2012 07:40 PM
Anyone from Brazil that can get any info, reps in the US are non-existent.
brandes.cm 9th August 2012 12:27 AM
HEF4070 is the IC and the resistor is 10ohm .25watt
timwebb 9th August 2012 12:47 AM
i never seen one.... thought it would be kinda bigger for a 8k amp.
brandes.cm 9th August 2012 02:53 AM
Efficient, using a microprocessor for all the pwm signals and IC's for the drive signals. All that is left would be the supply and input circuitry.
brandes.cm 18th September 2012 02:26 AM
The clip light is always on when I have the outputs enabled. If I disable the outputs with the switch clip light goes out until the input signal is increased.
Anyone have thoughts on this amp?
brandes.cm 18th September 2012 03:58 AM
The clip light is figured out, switch was put in the wrong state.
I get very little output of this thing, I can see the carrier with the 40hz on it, but after the filter I get nothing. The inductors are not open, maybe the cap?
Perry Babin 18th September 2012 12:49 PM
Is the pulse width of the PWM signal on the carrier going from near 0% to near 100%?
If not, the problem is the signal driving the input of the class D circuit.
brandes.cm 18th September 2012 06:45 PM
Originally Posted by Perry Babin (http://www.diyaudio.com/forums/car-audio/217481-soundigital-8k-post3169316.html#post3169316)
It doesn't seem to be, the layout of the 3 quad package op-amps has me baffled. A few have a square wave on the outputs while others have a triangle waveform and a few have the sine wave input signal.
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
