Soundigital 8K - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2013, 12:33 AM   #21
Cap measures 1uF, marked 105 630V.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 2nd January 2013, 12:54 AM   #22
If you place both probes on the same speaker terminal, do you get a perfectly clean trace that is precisely on the reference line?
If you connect a dummy load to the amp, does the current draw increase?
Old 2nd January 2013, 04:32 AM   #23
I pulled the inductors, will check them on the lcr meter at work.
If I connect a load the amp will pull 30 amps immediately upon a signal being applied.
Old 5th January 2013, 02:33 PM   #24
With both probes on the + speaker terminal I see this waveform.
Scope set to Add, channel 2 inverted, 50V/div, maybe 10uS/div
Old 5th January 2013, 05:29 PM   #25
Something is wrong. In differential mode, if you place the probes on the same point, the trace should not be deflected (should remain a straight line at the reference). It could be that the probes aren't matched well enough. Try placing them on a 12v DC source to see if they work properly. It could be a high-frequency response issue with one of the probes.
Old 5th January 2013, 07:19 PM   #26
Cal pot was messed up. Here is the output signal with 1khz input. Current increases until the signal starts to clip, then slowly drops.
Old 5th January 2013, 08:50 PM   #27
Did you find a problem with the inductors?
What was their inductance?
Does it still draw excessive current when you connect a load to it with no input signal?
Old 5th January 2013, 08:58 PM   #28
The inductors measured 20uH I believe, don't think it was 20mH.
If I load the output with 4 ohms the clip circuit is tripped. Then I get no output.
Sent from my DROID BIONIC
Old 5th January 2013, 09:05 PM   #29
What happens if you power it up with the load already connected?
Old 5th January 2013, 09:16 PM   #30
Clip light comes on, right away.
OT impedance help: 9.8 vs 8k clowkoy Tubes / Valves 2 9th May 2012 09:30 PM
Sound Digital 8K mike49504 Car Audio 64 19th February 2012 04:06 PM
Soundigital 16kd rodd1two Car Audio 6 19th February 2012 03:54 PM
CD94 Transport And DAC $8K? dantwomey Digital Source 5 20th March 2010 01:34 PM
Distortion at about 6-8K. Shoog Chip Amps 17 25th February 2007 04:41 PM
Copyright 1999-2017 diyAudio
