Soundigital 8K
Soundigital 8K
Old 18th September 2012, 07:44 PM   #11
luka is offline luka  Slovenia
luka's Avatar
Soundigital 8K
I would say, that could be input stage of clocked amp... triangle waveform + sine wave = pwm
what is the freq. of triangle waveform?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 18th September 2012, 08:50 PM   #12
brandes.cm is offline brandes.cm  United States
I'm guessing the frequency to be 40-80khz, I don't have it in front of me and basing it on my scope settings that I remember.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 18th September 2012, 08:51 PM   #13
luka's Avatar
Soundigital 8K
40-80k would still be pretty low for full range amp as this one should be if I remember right
I FEEL SLOVENIA
Old 18th September 2012, 08:52 PM   #14
Perry Babin is offline Perry Babin  United States
The amp requires that the input signal be equal to or greater than the amplitude of the triangle waveform to drive the amp to clipping. If the signal has an amplitude lower than that of the triangle waveform, the problem is in the preamp circuit, possible in the muting circuit (if it has one).
Old 1st January 2013, 10:26 PM   #15
What are the original outputs for this amp? The one I have is using IRFP90n20d. It was worked on before me without success, so I'm thinking these are not correct.
Old 1st January 2013, 10:36 PM   #16
Gate signals look good, just don't know why the output is not right.
Gate signals with no input signal.
5V/div
50V/div
Old 1st January 2013, 11:51 PM   #17
Those transistors are commonly used in the Brazilian amps.
What's wrong with the output?
Old 2nd January 2013, 12:01 AM   #18
This is the signal out of the amp, with or without an input signal.
50V/div 10us/div
Old 2nd January 2013, 12:05 AM   #19
It appears that you have a defective output filter (either the capacitor, inductor or both).
You didn't include the timebase setting so I'm assuming that it's set to 5-10us.
Are you using a differential probe setup to view this signal?
Does it appear to be trying to produce audio?
Old 2nd January 2013, 12:11 AM   #20
10us/div
Differential measurement is being used.
Yes you can partially see a sine wave if I slow the time base down.
I will pull the cap and measure it.
Soundigital 8KHide this!Advertise here!
OT impedance help: 9.8 vs 8k clowkoy Tubes / Valves 2 9th May 2012 09:30 PM
Sound Digital 8K mike49504 Car Audio 64 19th February 2012 04:06 PM
Soundigital 16kd rodd1two Car Audio 6 19th February 2012 03:54 PM
CD94 Transport And DAC $8K? dantwomey Digital Source 5 20th March 2010 01:34 PM
Distortion at about 6-8K. Shoog Chip Amps 17 25th February 2007 04:41 PM
Copyright ©1999-2017 diyAudio
