diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Orion 1200D (http://www.diyaudio.com/forums/car-audio/217194-orion-1200d.html)
S Merlington 2nd August 2012 02:24 AM
Orion 1200D
2 Attachment(s)
Does anyone know the value of theese ??
Im guessing they are a 3.3K resistor ..
Just wondering if thats correct Since they got hot and faded the color bands a lil..
They are measuring 2.766K out of the board So im just gonna replace them
tauro0221 2nd August 2012 02:47 AM
It look like orange orange brown = 330 ohms
S Merlington 2nd August 2012 02:53 AM
They look more red than brown thats why im wondering
tauro0221 2nd August 2012 02:59 AM
Check them with am ohmeter. You have 4 the same value. All 4 can not be bad.
S Merlington 2nd August 2012 03:01 AM
All 4 read different 1 measures 1k another one measures 2k one measure 2.7 k one reads 2.5k they are all bad evryone of them got very hot at some point on both driverboards..
tauro0221 2nd August 2012 03:02 AM
Sometime to get a good reading you need to lift one of the leg from the circuit.
S Merlington 2nd August 2012 03:04 AM
They are all out of the board right now and still get the same readings ANd i know my meter works 100% since i tested brand new resistors and they all check dead on
brandes.cm 2nd August 2012 03:24 AM
What do the resistors measure on the other driver board?
tauro0221 2nd August 2012 03:27 AM
Also do not forget to check the power transistors. You may have a shorted
transistor to blown 4 resistors or heated them up.
S Merlington 2nd August 2012 04:40 AM
They all measure the same as the first driverboard If you look at the backside of both driverboards thoose resistors got so hot they unsolderd themselfs from the board and made the driverboard black where they sit
Copyright 1999-2017 diyAudio
