#41 |
yes it was on master and yes i have a scope
#42 |
After pin 6 on the driver board drops to near 0v, do you see rail to rail oscillation on the output transistors? The oscillation will be on leg 3 of half of them and leg 2 of the other half. You may have to drive an audio signal into it to make it oscillate.
Set the scope to 5us and 50v/div. You may have to adjust the trigger level to get it to lock on the waveform. If you do see oscillation, do you have audio on pin 1 of the audio driver board?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#43 |
not getting any oscillation on any legs of output transistors or on pin 1 of driver board, driving input with 41hz tone
#44 |
Pin 1 should have normal audio.
Do you have ± regulated voltage on the power supply pins of the op-amps?
#45 |
which pins are power supply pins on op-amps?
#46 |
For an 8-pin op-amp, it's pins 4 and 8. 4 should have negative voltage and 8 should have positive voltage (approximately ±15v).
#47 |
i get -13v on pin 4 and -3.5 v on pin 8 of each op-amp
#48 |
It appears that the +15v regulator is defective. You'll have to determine what's being used for regulation. I don't have any information on this amp. If you can't find the regulator, post a photo of the entire board.
#49 |
j13 7815a and j14 7915A are 15v regulators
#50 |
Is the 7815 producing output?
Does it have input voltage?
| Troubleshooting Soundstream Rubicon 6.400 | frylock11 | Car Audio | 14 | 29th September 2011 08:03 PM |
| Soundstream Rubicon 1002 | mike49504 | Car Audio | 6 | 30th November 2010 03:41 PM |
| Soundstream Rubicon 302 | mike49504 | Car Audio | 20 | 6th June 2010 02:09 AM |
| Soundstream Rubicon 204 amp. need help ! | minde16v | Car Audio | 3 | 23rd November 2009 07:38 PM |
| Soundstream Rubicon 805 | audiobahnkid592 | Car Audio | 16 | 23rd July 2008 10:13 PM |
