#31 |
#32 |
It appears leaky but it could have been due to you touching the probes. Re-check it. Generally, if there is leakage, there is leakage no matter the orientation of the probes. If there was leakage on test 1, I would have expected it to show up on test 3.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#33 |
#34 |
it gave same result every time
#35 |
Try reinstalling the one that checked OK to see if the amp will power up normally.
#36 |
with Q44 removed amplifier powers up normally
#37 |
Did you reinstall the transistor that was in the Q43 location?
Does it produce audio?
#38 |
installed but i will check the audio
#39 |
#40 |
Do you have a scope?
If it has a master/slave switch, is the switch set to master?
| Troubleshooting Soundstream Rubicon 6.400 | frylock11 | Car Audio | 14 | 29th September 2011 08:03 PM |
| Soundstream Rubicon 1002 | mike49504 | Car Audio | 6 | 30th November 2010 03:41 PM |
| Soundstream Rubicon 302 | mike49504 | Car Audio | 20 | 6th June 2010 02:09 AM |
| Soundstream Rubicon 204 amp. need help ! | minde16v | Car Audio | 3 | 23rd November 2009 07:38 PM |
| Soundstream Rubicon 805 | audiobahnkid592 | Car Audio | 16 | 23rd July 2008 10:13 PM |
