Go Back   Home > Forums > General Interest > Car Audio
Old 29th July 2012, 03:10 PM   #1
Default Sundown SAZ-1500 excessive current draw
Originally the amp had failed supply and output fets. Supply is operational, output fets replaced, gate resistors verified. On power up amp with draw excessive current and it climbs with B+ voltage increase.
I can get the amp to stay out of protect by lifting D13 and using a current limit resistor. The outputs are IRF640N/IRF9640 pairs, essentially the AQ2200 schematic, same driver board with 4 transistors to drive the fets. The gate signal is roughly 40Khz on either rail. I only see a 5V square wave though, that seems to be my issue.
Thoughts,
IRF640N gate signal, gnd is two divisions above center.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 29th July 2012, 03:31 PM   #2
timwebb is offline timwebb  United States
ive have those output drive transistors to fail very easy. ive have plenty that tested good but were defective.
Old 29th July 2012, 05:00 PM   #3
Note: 1)These amps do not like bringing the supply voltage up slowly, gets caught in some unknown region and causes excessive current.
2) The nomenclature on the board is wrong for the rca inputs, what says "out" is in.
3) Output section resembles AQ2200 and a host of Hifonics etc boards that use DWM1216 card.
Old 29th July 2012, 05:25 PM   #4
are the output fets in, in the second picture?
Old 29th July 2012, 05:32 PM   #5
Lifting D13 allows the amp to function, producing clean audio output. I need to hunt down the source of this protection issue.
Old 29th July 2012, 08:24 PM   #6
Anyone recognize this board, maybe have a schematic for another amp that is close.
Old 30th July 2012, 12:35 AM   #7
How much difference is there between the AQ2200 that you mentioned and this amp?
Old 30th July 2012, 12:40 AM   #8
This reminds me of a hifonics hercules, but I think that the hercules has a diff driverboard and more outputs, but the rest looks the same. Are those irfp064's in the ps section? Does it run a ka7500 on the ps driverboard?
Old 30th July 2012, 12:45 AM   #9
I had a sundown 3000d in here last week with protect issues, turned out to be the npn transistor hooked to pin 8 on the driverboard (but it's a bigger driverboard than your 1500).
Old 30th July 2012, 01:06 AM   #10
The AQ2200 uses a power supply driver board. I can't find why the protect trips right on power up. I lifted the inductors inline with the current sense for the outputs, still tripped.
Not sure where to start.
Schematic? Sundown SAZ-1500, Elevation Audio DX1500.1, RD 1750.1, Atomic AT-1600.1D ThyDntWntMusic Car Audio 22 27th April 2012 04:42 AM
JL 1000/1 excessive current draw bjrog2 Car Audio 9 26th April 2012 07:57 AM
Need sundown saz-3000d audio driver board info/pic 807tubenut Car Audio 17 11th March 2011 05:47 PM
Sundown SAZ 3000 D mike49504 Car Audio 36 8th November 2010 08:56 PM
Excessive current draw in Fender Deville Rockin' Andy Tubes / Valves 4 20th January 2007 09:41 PM
Copyright ©1999-2013 diyAudio
