Digital Designs Z1
Digital Designs Z1
Old 13th September 2012, 10:06 AM   #11
WoutRam is offline WoutRam  Netherlands
Default dd z1
I checked on my Z1:
The diode you refer to is marked D10.
The text on the housing says: ¨B22¨ (or B2Z, hard to tell).
B22 makes sense; a 22 V zener diode
B2Z doesn´t make sense to the best of my knowledge.
I tried to make a picture of the controller board so that you might be able to read component-numbers. However, that wasn´t succesful.
Wout Ram
Originally Posted by S Merlington View Post
I got this amp off a friend of mine and it appears someone tryed repairing it themselfs..
Im going to rebuild the output driverboard since it looks like a bad reapir
There is a diode missing its marked B2F any ideas on what part number that may be??
I already call DD and they have nothing on the driverboard
The diode goes between the SD pin (pin3) and the COM pin (pin4)
Old 21st September 2012, 10:00 PM   #12
ThyDntWntMusic is offline ThyDntWntMusic  Australia
to the OP, the pictures you posted look very similar to mine (quality wise) the amplifier has most likely been modified to prevent turn on pop, and lower the low voltage protection... hence the messy, "aftermarket" soldering
I have schematics for the whole amp... minus the driver board, as DD appear to have just used off the shelf items, and if they failed, would just replace the whole driver board.
Old 22nd September 2012, 03:30 PM   #13
Could you check for me the following values on the second controller board (the one for the power supply) of the Z1:
- typenumber or value of D4 (missing on my PCB)
- value of R22 (100 ohms on my PCB; seems rather low value)
- value of R21 (100K ohms on my PCB; seems rather high value)
- value of R3 (not the original component on my PCB)
Thanks!
Old 25th September 2012, 08:36 AM   #14
D4, I THINK it's a 1N4247, I actually have two of these amps, one is in pieces, and can read 1N4* on the diode (I believe it's 1N42) but can't read the other two numbers, because of the way the diode is formed...
however, I have some photos of the other amp (it's not in my possession at the moment) but it appears to have 47 at the end of the part number
R22 is 100 ohm
R21 is 100k
R3? where's that on the board?
Old 25th September 2012, 07:24 PM   #15
Thanks for the information!
However, 1N4247 is a regular diode while D4 has to be a zener diode.
D4 should be a zener diode of - best guess - approx. 15V.
So typenumber should be 1N4744, 1N5245, ....
Could you please be as kind as to check again?
R3 is on the edge of the PCB, just above the 6 pin connector marked X1
Old 25th September 2012, 08:32 PM   #16
If you want D4 to be a zener diode, then put a zener diode in there.
I'm not spending my time removing the part just to check the value for you.
As for R3, I have two of these amps... on one board, its 33 ohm, on the other it appears to be 2.7 ohm
Old 26th September 2012, 05:55 PM   #17
I did not ask to disassemble components, just a request to have a second look.
Thanks for the information concerning the resistors!
Digital Designs Z1Hide this!Advertise here!
digital designs akis Digital Line Level 1 16th April 2012 05:56 AM
Digital Designs Z1 repair WoutRam Car Audio 1 18th November 2011 04:12 PM
Digital designs Z2 mike49504 Car Audio 11 8th October 2011 01:26 AM
Digital Designs Z1 mike49504 Car Audio 21 23rd October 2010 03:46 PM
Digital preamp designs? Helix Digital Source 11 13th September 2001 12:14 PM
