RF T20001bd output drive issue - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 24th July 2012, 02:33 AM   #1
Default RF T20001bd output drive issue
I assume there should be a ~40Khz signal at the gate pad of the output fets in this amp. It seems to have a half-bridge type config, with HV+ switched from one side and HV- switched from the other and vice versa?
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 25th July 2012, 02:36 AM   #2
The rails are shifted above or below ground depending on where the voltage is needed.
If you don't have rail-rail oscillation, you don't have excessive DC on the speaker terminals and the amp isn't in protect mode, confirm that you have the triangle waveform on the pins marked 'carrier' on the schematic diagram.
Gain Pot RF T20001BD vypr Car Audio 1 1st December 2010 08:34 PM
RF 400x4, output channel distortion sulaiman b Car Audio 13 29th August 2010 06:28 PM
Disassemble RF T20001BD vypr Car Audio 6 11th May 2010 04:09 PM
RF 250a2 1.9Vdc on output brandes.cm Car Audio 24 7th October 2009 12:53 AM
Help with RF 800a4 bridging issue carcomp Car Audio 5 19th May 2008 11:49 PM
Copyright 1999-2017 diyAudio
