Neg rail voltage on two pads? - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 25th July 2012, 08:31 PM   #11
I need the voltages from the 14 pin header on the audio driver board, not from the power supply driver ICs.
Old 26th July 2012, 02:33 AM   #12
Deadly Sones's Avatar
All 14 pins have between -106.6VDC and -115VDC when I put the black probe on the secondary winding ground and the red prob on the pins.
Old 26th July 2012, 08:40 AM   #13
Look at the schematic that I sent you. the voltages are given on the amp page.
Old 26th July 2012, 01:23 PM   #14
In looking at the readings I should have, I figured I must have been doing something wrong...
After some more studying your tutorial, I decided to try using the negative rail source pad closest to the audio section as the reference to ground. Now I have the following voltages.
Pin 1: 8.600vdc *
Pin 2: 8.700vdc *
Pin 3: 3.400vdc *
Pin 4: 8.800vdc *
Pin 5: 5.400vdc *
Pin 6: 3.200vdc *
Pin 7: 0.001vdc
Pin 8: 8.900vdc *
Pin 9: 12.50vdc *
Pin 10: 1.620 to 3.100vdc *
Pin 11: 0.003vdc
Pin 12: 2.100vdc *
Pin 13: 2.100vdc *
Pin 14: 13.98 vdc
All pins with a "*" fluctuate rapidly several point volts to nearly 1v... what could be causing this?
If I'm reading that schematic you sent me right, I should have 12v +&-, 15v +&- on 4 of them pins? Where are those voltages regulated from?
Old 26th July 2012, 02:16 PM   #15
I also took the readings from what I believe to be the dual op amp.
Pin 1: 0.051 *
Pin 2: 115.9
Pin 3: 116.1
Pin 4: 0.044 *
Pin 5: 0.001 *
Pin 6: 7.1 - 9.2 *
Pin 7: 0.095 *
Pin 8: 14.00
Again all readings are with the neg probe on the source pad of the neg rail closest to the audio section. Voltages with "*" are fluctuating slightly except for pin 6 that one fluctuates greatly.
Old 27th July 2012, 12:01 AM   #16
It doesn't appear that the main power supply is producing rail voltage. Do you have positive and negative rail voltage?
Old 27th July 2012, 12:50 AM   #17
Yes, I think so. The results are posted in my first post.
Old 27th July 2012, 12:59 AM   #18
You need to confirm that that's still the case. Pin 8 should be very near -120v DC.
Old 27th July 2012, 02:07 AM   #19
yes. I have -116.3 on the source and -115.5v on the gate. Placing the - probe on the center tap and + on the pads. I double checked the voltages on pin 8 too... it was the same. I put the neg probe on the source pad of the first neg rail pad.
Old 27th July 2012, 02:25 AM   #20
If you mean that it's the same as you posted (8.9v), you need to determine why pin 8 doesn't have negative rail voltage.
Confirm that one of the secondary center taps of the small transformer are directly connected to the negative rail.
Do the various audio op-amps have positive and negative regulated voltage on their power supply pins?
s150 blown neg rail fuse joegio Pass Labs 8 6th February 2013 01:33 AM
Neg Rail on JLH Amp Output john65b Solid State 23 13th January 2012 02:45 AM
F5 loaded rail-to-rail voltage? CanAm Man Pass Labs 40 20th March 2011 08:43 PM
Can 555 circuit supply enough neg voltage graygem Analog Line Level 1 1st March 2011 06:19 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 23rd July 2002 12:50 AM
Copyright 1999-2017 diyAudio
