Neg rail voltage on two pads?
Old 27th July 2012, 01:46 AM   #21
Deadly Sones is offline Deadly Sones  Canada
Deadly Sones's Avatar
Yes, I only have 8.9v on Pin 8.
As far as the voltages on the op amps, the only one I see is on the upper left of the board. 8 pin IC. The dual op amp has the same voltage on pin 6 as pin 8 of the other IC.
These are the voltages I found from that IC:
Pin 1: 0.051 *
Pin 2: 115.9
Pin 3: 116.1
Pin 4: 0.044 *
Pin 5: 0.001 *
Pin 6: 8.9 *
Pin 7: 0.095 *
Pin 8: 14.00
Again the "*" means voltage was fluctuating
Could you please point me to the proper "small transformer" I should be using the center tap to check to neg rail? thanks.
Old 27th July 2012, 01:52 AM   #22
Perry Babin is offline Perry Babin  United States
The small transformer is the one near the power supply driver board.
Old 27th July 2012, 01:58 AM   #23
When I place one prob on the center tap of the small transformer, and the other on the neg rail it reads 0.000v but flickers between OL and 0.000ohms repeatedly.
Old 27th July 2012, 02:14 AM   #24
Not sure how relevant it is, but when I bought this amp it only had a few power supply transistors (no outputs at all) and these two driver transistors were shorted. I replaced them (in the yellow square) and checked all the resistors and the power supply appears to have powered up and it stopped going into protection. Could I have missed something when I did this repair? I know R4 looks smoked but it has proper resistance.
Old 27th July 2012, 02:42 AM   #25
I don't know what #23 means because I don't know how your meter responds. Find a way to determine definitively that one of the secondary center-taps for the small transformer is directly connected to the negative rail.
If you have a scope, make sure that you have oscillation on the tabs of the two FETs for the small transformer. It should swing from ground to ~24v.
I can't read the circuit boar designations for the drivers you replaced so I don't know what they're used for.
Old 27th July 2012, 09:35 AM   #26
K. I'm going away for the weekend so I'll continue this next week. Thanks for all your help Perry. To be continued....
The circuit designations for them two transistors is QP2 and QP4.
Neg rail voltage on two pads?Hide this!Advertise here!
s150 blown neg rail fuse joegio Pass Labs 8 6th February 2013 12:33 AM
Neg Rail on JLH Amp Output john65b Solid State 23 13th January 2012 01:45 AM
F5 loaded rail-to-rail voltage? CanAm Man Pass Labs 40 20th March 2011 07:43 PM
Can 555 circuit supply enough neg voltage graygem Analog Line Level 1 1st March 2011 05:19 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 22nd July 2002 11:50 PM
Copyright ©1999-2017 diyAudio
