RD Audio RD-3250v2
RD Audio RD-3250v2
Old 21st July 2012, 04:09 PM   #1
S Merlington is offline S Merlington  United States
Default RD Audio RD-3250v2
Wondering if anyone knows the value of this resistor that sits behind the speaker terminals ??
It got hot and cannot make the color bands out that well..
It measures 31.00 K on my meter but not sure if thats what its suppose to read..
Also does anyone know what caps i need they are the plastic rectangler caps and they are marked 6n6 J100 anyone know the value of them?
Old 21st July 2012, 11:42 PM   #2
Perry Babin is offline Perry Babin  United States
The resistance will likely be much lower (less than 10 ohms). Contact RD Audio for the value.
The cap (from the information you provided) is a 6.6nanoFarad (0.0066uF) 100v cap with a 5% tolerance.
Old 24th July 2012, 05:59 AM   #3
Next question is theres a diode marked C10 5T that connects to the base of the A1275 drivers along with a 510 ohm resistor..
Does anyone happen to know what diodes i can replace them with or a part number?
Old 24th July 2012, 12:18 PM   #4
brandes.cm is offline brandes.cm  United States
Is the diode bad? I haven't run across a bad one in that circuit.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 24th July 2012, 03:09 PM   #5
Its missing
Old 25th July 2012, 02:51 AM   #6
Did you try contacting RD Audio to get the part number or a replacement?
Old 25th July 2012, 08:15 AM   #7
Yes they dont have anything on the amp They said it was made before they bought the company.
Old 25th July 2012, 08:00 PM   #8
If it's missing, where did you get the numbers?
Old 25th July 2012, 10:17 PM   #9
Theres 4 of them in the amp they are connected from the drain of the power supply fets to the base's of the drivers along with a 510 ohm resistor
Old 25th July 2012, 10:39 PM   #10
If it connects directly from the drain to the base of the driver for the same FET, it's not likely to be a standard or Zener diode. It's more likely to be a bi-directinal TVS. Post a photo of the component.
RD Audio RD-3250v2Hide this!Advertise here!
FS: Dodd Audio built Class D Audio/SDS 254 kregg007 Swap Meet 0 14th November 2011 12:14 AM
Good books or videos on audio production, audio engineering, or audio editing tunks14 Everything Else 0 15th April 2011 10:00 PM
For Sale Or Trade: Adire Audio Brahma, Rythmik Audio Plate Amp tmort Swap Meet 5 27th June 2009 12:29 AM
Need schematic for Elevation Audio DX1500.1/Sundown Audio SAZ-1500D jaimegmr Car Audio 0 5th May 2009 06:39 PM
