focal fp 2.150 power, no sound
Old 18th July 2012, 10:04 PM   #1
oldguyoklahoma is offline oldguyoklahoma  United States
Default focal fp 2.150 power, no sound
I have a focal fp 2.150 amp that powers up but has no sound. It is not in protect mode. Found a shorted power trans and r&r it. everything looks good but no sound. Has voltage going to all transistors. 46volts pos and 46 neg.. ran a signal into it but without a road map i am shooting in the dark.
Old 18th July 2012, 11:09 PM   #2
Perry Babin is offline Perry Babin  United States
If no one can help, post a photo of the inside of the amp.
Old 19th July 2012, 06:18 AM   #3
ok hope this works. this is a picture before I did anything. Just popped the top to see if anything was BBQ'd. The only thing I found make a long story short was a shorted transistor. TIP35D which i r&r'd.
Someone else has been here before me. rrrrr. What a mess.
Old 19th July 2012, 06:29 AM   #4
http://www.focal.com/files/fiche-technique-fp2-150.pdf
This my help. It has more protection circuts than i have ever seen in a amp.
Old 19th July 2012, 07:31 PM   #5
Is there any significant DC voltage across either pair of speaker terminals?
Old 19th July 2012, 07:37 PM   #6
there was before I changed the trans. the right channel had full dc to the treminals.
Old 19th July 2012, 08:01 PM   #7
There may be significant damage to the drive circuit and possibly to the protection circuit. Most DC offset protection circuits shut the power supply down so that no significant DC can be driven into the speakers.
Did you check the emitter resistors?
Did you check the other output transistors in the circuit to see if they were open?
The board seems to have some discoloration around some of the drive components. All of the transistors in that area need to be checked.
Old 20th July 2012, 12:41 AM   #8
Ok. The amp powers up. Not into protection. Has voltage to all the drivers. Now you may have something on damage to the driver circuit. the discoloration you were seeing is flux from the person/s who were in this thing before me. Who ever worked on this amp instead of unsoldering the drivers they just cut the legs and resoldered them back together. Lazy to me, guess I do it the old way. Guessing that they found one driver that was shorted and just didn't remove it just left it cut. that was how i found the dc voltage on the speaker terminals. Gotta love fixin other peoples screw ups just to get to square 1. I do have this same amp in new in the box that i could use for referance.
Old 20th July 2012, 01:02 AM   #9
sorry forgive my stupidness. the emitter resistors are the large white resistors.
Old 20th July 2012, 08:21 PM   #10
Yes. The emitter resistors are the large white resistors.
focal fp 2.150 power, no soundHide this!Advertise here!
PSA 150 S (pure sound amplifier)---help needed sergiu2009 Solid State 67 29th August 2011 09:49 PM
capacitor upgrade for Focal 2.150 amplifier muddasirwaheedmalik Solid State 0 23rd August 2011 10:12 PM
Van Alstine Mosfet 150 Modified Dynaco ST 150 Power Amp Scott Novak Swap Meet 1 7th August 2009 11:45 PM
Pass INT-150 Review in Absolute Sound hifimaker Pass Labs 5 14th August 2008 07:36 AM
MTM design FOCAL 6W4311 AND FOCAL Focal TC120 Tdx2 Bas Horneman Multi-Way 1 5th February 2003 05:21 PM
