soundstream picasso PCA2.260 dont turn on
Old 17th July 2012, 01:05 AM   #1
Solosound is offline Solosound  Mexico
Solosound's Avatar
Unhappy soundstream picasso PCA2.260 dont turn on
I have now an Asian design sound stream Picasso pca2.260
The amplifier don't turn on
I found damaged the 2 next transistors
I changed but the amplifier continue death
the voltages from the TL494cn
1 1.45
2 3.10
3 4.67
4 0.04
5 1.5
6 3.4
7 0.00
8 11.7
9 0.0000
10 0.0035
11 11.7
12 11.7
13 4.97
14 4.97
15 4.97
16 5.8
I need a little help from my friends
Old 17th July 2012, 01:36 AM   #2
Perry Babin is offline Perry Babin  United States
Pin 16 is being driven high. That's shutting the pulses down. Find what's driving pin 16. If it's a transistor, remove the transistor to see if the amp will power up and produce audio. Be careful because this will disable the protection circuit for the amp.
Old 26th July 2012, 01:22 AM   #3
Solosound's Avatar
Greetings to all.
Thanks to Perry's tutorial, I found the diagram of the amplifier:
following clues I find the problem, the transistor Q208. KEM Part C3198, which is leaking.
This leaking part cause variation of feeding of Operational Amplifiers, activating the protection (see 16 and voltages on pin 3 of PWM) and sending DC to the audio output ....
When I remove it, everything returned to normal, now just put a new one.
Here is a bit difficult to get parts KEM.
Is there somewhere to help us with their equivalents?
Thank you very much everyone for your comments and help
Old 26th July 2012, 08:38 AM   #4
That's just a generic schematic. It's the basic circuit used by many of the budget amplifiers (with slight variations). If you look at item 33 on the power supply troubleshooting page, there are several links to schematics for common circuits. Each one lists indicators that help you identify the type of circuit.
The part isn't going to be critical. Virtually any NPN transistor with the same pin configuration and greater or equal voltage/current ratings will work.
soundstream picasso PCA2.260 dont turn onHide this!Advertise here!
anyone have soundstream reference picasso schematic clear version russdeanlee Car Audio 4 30th March 2012 08:29 AM
soundstream reference picasso russdeanlee Car Audio 6 18th February 2012 09:40 PM
soundstream picasso class a amp question russdeanlee Car Audio 4 24th December 2011 08:15 PM
Soundstream PCA2.760 mike49504 Car Audio 2 11th June 2011 05:13 AM
Soundstream Picasso 1.1700D mike49504 Car Audio 1 2nd November 2010 10:56 PM
