Go Back   Home > Forums > General Interest > Car Audio
Old 15th July 2012, 05:22 AM   #1
Default Sony XM-GTX6040
Amp will not power up its dead I have 0 volts on all pins of the 594 any suggestions?
Old 15th July 2012, 11:09 PM   #2
Follow the trace back from pin 12. IT likely goes to a Q901. Post the voltage on all 3 legs of Q901 (or whatever transistor it goes to).
Old 15th July 2012, 11:55 PM   #3
It goes to Q902
I have 0 volts on all 3 legs
Old 16th July 2012, 12:35 AM   #4
Are you sure that the fuse isn't blown?
Old 16th July 2012, 12:38 AM   #5
Both fuses looked fine but i replaced them and the amp powers up perfectly Thanks for the info
Old 10th August 2012, 07:20 PM   #6
Amp worked for about a week and came back to me and it wont power up again..
I replaced both fuse's with new and the amp still wont power up..
I have 0 0.00 volts on all 3 legs of Q902
I also have 00.00 volts on all pins of the 594
Old 10th August 2012, 09:00 PM   #7
Did you pull the board to look for bad solder connections or burned traces?
Old 10th August 2012, 09:32 PM   #8
Yes do see any.. I will heat up the solder and see if that does anything
Sony XM-475GSX mike49504 Car Audio 3 28th April 2012 03:50 PM
SONY XM-2252HX mike49504 Car Audio 0 27th April 2012 01:03 AM
Sony XM-405EQX mike49504 Car Audio 3 14th February 2012 01:03 AM
Sony XM-1002HX mike49504 Car Audio 1 29th July 2011 02:47 AM
Sony XM-4520 croccodillo Car Audio 0 14th December 2005 09:19 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
