spund stream rubi 1000d
Old 15th July 2012, 11:27 PM   #11
Perry Babin is offline Perry Babin  United States
That would seem to indicate that the problem is with transistors Q124-Q127 or the resistors connected to those transistors. It could also indicate that the board itself is conducting.
Old 18th July 2012, 12:40 AM   #12
timwebb is offline timwebb  United States
where are these two? im over looking them.
Old 18th July 2012, 12:47 AM   #13
They are on the driver board. Q124 and Q125 are the MPSA42s that commonly fail.
Old 21st July 2012, 09:32 PM   #14
the MPSA42s on this card are in q35 q36 q40 q41. ive replaced them all due to the legs were discolored from heat. can a resistor be defective if it still read correct?
Old 21st July 2012, 11:58 PM   #15
Generally, there are only 2 transistors between the MPSA42s. Are you sure that you have the transistors in the correct locations?
If you shine a bright light from the back of the board, are there any areas between the solder pads that won't pass light?
Old 22nd July 2012, 06:33 PM   #16
i changed the two resistors between the MPSA42 transistors and it works now.
spund stream rubi 1000dHide this!Advertise here!
1000D Memphis Amp ? Hoppy72450 Car Audio 11 22nd December 2017 10:25 AM
soundstream rubi 2500 timwebb Car Audio 14 5th February 2012 01:25 AM
memphis 1000d timwebb Car Audio 36 28th August 2011 11:30 PM
another memphis 1000d timwebb Car Audio 3 11th April 2011 03:14 AM
Memphis 1000D transformer. tgdrums1990 Car Audio 4 16th June 2010 03:32 PM
