Lanzar MXA282 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 7th July 2012, 06:04 AM   #1
Default Lanzar MXA282
This amp is in protection mode all outputs test fine..
Heres what i get on the 494
Pin 1: 0.04
Pin 2: 4.99
Pin 3: 4.74
Pin 4: 0
Pin 5: 1.49
Pin 6: 3.46
Pin 7: 0
Pin 8: 13.91
Pin 9: 0
Pin 10: 0
Pin 11: 13.91
Pin 12: 13.16
Pin 13: 4.99
Pin 14: 4.99
Pin 15: 4.99
Pin 16:11.16
Any suggestions on what to look at?
Old 7th July 2012, 06:29 AM   #2
Something is driving pin 16 high. That's shutting the supply down.
Post a photo of the board.
Old 7th July 2012, 09:45 PM   #3
Heres a couple of pics ..
When i try to power the amp up the power light comes on for 2 secs then fades out and amp shuts right off
Old 7th July 2012, 09:56 PM   #4
Post the DC voltage on all 8 pins of the IC next to the TL594.
IC#
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 7th July 2012, 10:02 PM   #5
IC# JRC 2904D
Pin 1: 0
Pin 2: 12.31
Pin 3: 6.52
Pin 4: 0
Pin 5: 11.48
Pin 6: 4.99
Pin 7: 11.56
Pin 8: 13.15
Old 7th July 2012, 10:21 PM   #6
Have you checked all of the output transistors to confirm that none are shorted?
Old 8th July 2012, 02:25 AM   #7
lol, just repaired the exact amp a couple months ago. anyways, looks like this one has been repaired before, especially obvious with the one mismatched rail cap (the black one.) the 2 on the other side look to be bad, or going south. is that leakage below them? also, look at the one above r203. i would also check the to-220 drivers between the top outputs in the pic. it looks like one might be touching the screw, or the other could be contacting beyond the pad. all i can see.
Old 10th July 2012, 01:06 AM   #8
I found the drivers for the power supply fets to be defective..
The amp uses IRFZ44V's for the fets with 100 ohm gate resistors..
The amp is using A1015 and C1815 as the drivers..
Are there any good subs for the drivers?
Old 10th July 2012, 01:11 AM   #9
Are you sure that they're defective?
It's rare for the drivers to fail if the FETs are not defective.
Old 10th July 2012, 02:52 AM   #10
Positive they are defective amp draws excessive current when trying to power up so i removed the drivers and they are shorted from legs 2 to 3
Old lanzar help needed Buggen Car Audio 0 13th May 2012 06:01 PM
Lanzar Vibe 256 mike49504 Car Audio 1 12th August 2011 04:27 AM
Lanzar 100q mike49504 Car Audio 26 29th June 2010 06:36 PM
Need Help With Lanzar OptiDrive KansasKowboy Car Audio 2 1st April 2010 03:41 PM
Lanzar 600-S schematic Diode Car Audio 0 22nd March 2003 02:39 AM
Copyright 1999-2017 diyAudio
