diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Power Acoustic A3000DB (http://www.diyaudio.com/forums/car-audio/215738-power-acoustic-a3000db.html)
S Merlington 6th July 2012 07:53 PM
1 Attachment(s)
Anyone know the value of R101 it sits directly behind the rca jacks
Perry Babin 6th July 2012 08:03 PM
220 ohms.
This problem can be caused by a shorted transformer or by having the positive speaker output wire shorted to ground.
S Merlington 6th July 2012 08:08 PM
Would this also cause the amp not to power up?
Perry Babin 6th July 2012 08:10 PM
Not by itself but I've seen quite a few amps come in with this resistor burned and the SG3525 blown.
Post the DC voltage on all pins of the 3525 if you can't determine why it's not powering up.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
S Merlington 6th July 2012 08:19 PM
Pin 1: 0
Pin 2: 0.50
Pin 3: 0
Pin 4: 0
Pin 5: 0.21
Pin 6: 0
Pin 7: 0.18
Pin 8: 0.73
Pin 9: 0.50
Pin 10: 0
Pin 11: 0
Pin 12: 0
Pin 13: 11.88
Pin 14: 0
Pin 15: 11.88
Pin 16:0.50
Perry Babin 6th July 2012 08:26 PM
The lack of 5v on pin 16 makes it appear to be defective. The problem could be the 3525 or something connected to pin 16 dragging the voltage down.
S Merlington 6th July 2012 08:59 PM
You were correct the 3525 was defective..
Thanks for your help..
Resources saved on this page: MySQL 18.75%
