Soundstream PCA2000D
Old 5th July 2012, 05:02 PM   #21
m4ick is offline m4ick  United States
On IC103 in DCV I read:
1. -8.1V
2. -0.7v
3. 0.00v
4. -15V
5. -8.2
6. -8.2
7. -8.2
8. +15V
I replaced it due to excessive DC but I still have DC on all of those pins except 3 which is tied to secondary CT.
Is this IC defective again or could something else be driving -8V to it?
This is the IC that directly feeds pin 1 of the driver board.
Scope - DMM - 460W Computer PSU - Tutorial
Old 5th July 2012, 08:18 PM   #22
Perry Babin is offline Perry Babin  United States
Confirm that the master/slave switch is working properly. Testing the connections between the components on the board (the ones connected to the switch) will be the most reliable way to test.
Old 6th July 2012, 04:19 PM   #23
Yes, I get continuity on all the right connections and they switch with the switch
Old 6th July 2012, 07:01 PM   #24
Do you have any DC voltage (more than a few millivolts) across the speaker terminals?
Old 11th July 2012, 06:17 PM   #25
0v across the speaker terminals, no outputs are installed.
Old 12th July 2012, 02:09 AM   #26
Was the op-amp that you replaced a new op-amp of the same part number?
Did you take the measurements with no input signal?
Old 15th July 2012, 02:17 PM   #27
It was the same part from another clone amp that had signal at the driver board.
Measurements were taken with input signal, there is no input signal on that IC.
Old 15th July 2012, 11:24 PM   #28
Are you sure that it's IC103 and not IC106 (pin 7) that's driving pin 1 of the driver board (pin 1 of the driver board being nearest the RCA inputs)?
Soundstream PCA2000DHide this!Advertise here!
Soundstream MC245 . . . Again poopydoopynoopy Car Audio 10 12th May 2010 02:37 AM
soundstream dbx sub audiobahnkid592 Car Audio 4 6th January 2009 11:59 PM
Soundstream shaolinfox30 Car Audio 1 24th July 2007 09:03 AM
soundstream 6.0 ben04srt Car Audio 10 11th March 2007 04:56 AM
Soundstream? thylantyr Pass Labs 6 10th November 2006 08:35 PM
