Go Back   Home > Forums > General Interest > Car Audio
Old 6th July 2012, 04:19 AM   #31
Jatruh is offline Jatruh  United States
Well I put 12v across the coil and nothing. It doesn't look bad but one of the windings must have broke?
Old 6th July 2012, 04:24 AM   #32
Yep that looks like it will work. I will order tomorrow and post when installed. Thanks again.
Old 6th July 2012, 04:35 AM   #33
One more question Perry, The 3.3k Resistors R156, R198, R205, & R216. What is the part number? I looked on Digi-key and want to make sure I get the right one. I accidentally chipped off some of the ceramic coating, or what ever it is. I was trying to make the amp look nicer by pulling it up into place, it was crushed down.
Old 6th July 2012, 04:55 AM   #34
See if this one will fit. If you need a larger or smaller resistor, change the 2tr to 1tr or 3tr.
P3.3KW-2TR-ND
Old 6th July 2012, 05:04 AM   #35
Do you have the schematic? If so could I have a copy? Thanks again Perry, you are the man.
Old 6th July 2012, 05:16 AM   #36
Not for this amp.
Old 10th July 2012, 12:36 AM   #37
Well, I received the parts today and it works! The only problem is they sent me the relay with the sealed case and not the open one. So the crossover board doesn't screw down. I rigged it for now by desoldering the pins and pushing them down farther through the board to allow them to make proper contact and added spacers to keep it from bending the board. I will just make a new endcap and shave the pots down a hair. I learned alot and am glad that it's working again. I appreciate all your help. Thanks again.
Old 10th July 2012, 01:44 AM   #38
Most of the relays of this type/style are virtually identical in size. Are you sure that the relay is all of the way down in the board?
Old 10th July 2012, 02:45 AM   #39
I will have to take some pics to show you, my relay sits under the crossover board. My relay is not enclosed in a case because of this to allow it fit under the board. I've seen the pics of the boards with the relay between the caps, but haven't seen anyway like this on here. When I ordered it, it showed the correct relay and said you had to order the cover. I don't know what happened but it works. Ill try to post them tomorrow.
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
kicker C-15 crazycody1993 Subwoofers 5 24th November 2011 03:51 PM
Kicker zx150.2 mike49504 Car Audio 42 24th February 2010 04:03 AM
Kicker L7 skooter Car Audio 5 25th September 2008 11:36 PM
kicker warhorse tadej Car Audio 10 17th August 2008 03:05 AM
Copyright ©1999-2013 diyAudio
