Need Help with another Kicker 04kx1200.1 - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 5th July 2012, 10:56 PM   #21
Can you reach the relay pins for the coils. If you can read the pins voltages. It would tell if you have a problem in the relay enable driver.
Old 5th July 2012, 11:31 PM   #22
Jatruh is offline Jatruh  United States
The only relay I can see is under the pre-amp. It has 13.6v DC on it, but it doesn't click so it must not be receiving a ground input?
Old 6th July 2012, 12:06 AM   #23
Yes, you get it right. Now the problem it is to find why. Now it is when you need the schematic to find out how it is enable.
Old 6th July 2012, 01:40 AM   #24
Measure the DC voltage directly across the terminals of the diode at the base of the relay. Do you have approximately 0v or approximately 12v?
All of the previous tests were to determine if there was a reason for the relay not to engage. It appears that the amp is working properly.
Old 6th July 2012, 01:46 AM   #25
13.7v at the diode.
Old 6th July 2012, 01:51 AM   #26
-13.7v if I place the black probe on the cathode side and the red probe on the anode.
Old 6th July 2012, 03:11 AM   #27
If this diode is directly across the relay coil (I assume that it is), the relay is defective.
Old 6th July 2012, 03:35 AM   #28
I think to enable the relay you need 13 volt at one side of the relay and the other side should be zero. So that's means that the cathode of the diode should be zero and the anode it should be 13 volts. A zero at the cathode will enable the relay.
Old 6th July 2012, 03:42 AM   #29
I will pull it from the board and test it. Any part number and place to order it from? Thanks for your help hope this is it.
Old 6th July 2012, 04:16 AM   #30
If the relay is defective, the following should work. Compare pin configurations before ordering.
Digi-Key Part Number: PB110-ND
kicker kx1200.1 timwebb Car Audio 8 24th January 2012 02:38 AM
kicker C-15 crazycody1993 Subwoofers 5 24th November 2011 03:51 PM
Kicker zx150.2 mike49504 Car Audio 42 24th February 2010 04:03 AM
Kicker L7 skooter Car Audio 5 25th September 2008 11:36 PM
kicker warhorse tadej Car Audio 10 17th August 2008 03:05 AM
Copyright 1999-2017 diyAudio
