Hi, I am looking for JL audio 1000/1 schematic.
thanks |
#2 |
They are virtually impossible to get. What do you need to know?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#3 |
The problem is that, it is turning on and off, draws large current without any load. All output FETs are ok, all diodes OK. On FET there is only 5.7V.
Capacitors looks ok. No burnt part visible also. Any idea? Thanks |
#4 |
The amp is going to draw fairly significant current when it powers up. Was it blowing fuses in the vehicle?
#5 |
It doesnot blow fuses, just power led blinks. I can see current draws more than 5 amps and then goes down. looks like, power supply side problem. no audio.
schematic would be helpful. thanks |
#6 |
Does it do this on a car battery?
Are you using a power supply to try to power it up? These amps are VERY sensitive to dips in voltage and will shut down if it drops too low. The dip in voltage that's too quick to be read with a multimeter can shut it down.
| Jl audio 500/1 powers on with low audio out help needed | ivkata | Car Audio | 29 | 19th August 2011 12:21 AM |
| JL 500/1 Schematic | TotalNovice123 | Car Audio | 4 | 6th July 2011 03:27 AM |
| Can I run a 10 inch JL audio and a 12 inch JL audio off same amp | ash4kel | Car Audio | 2 | 8th April 2011 02:12 AM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
