Rockford fosgate deck! Anyone repair these?
Old 22nd June 2012, 04:43 AM   #1
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Default Rockford fosgate deck! Anyone repair these?
Hello everyone, I have a Rockford fosgate RFX 8310 cd player. It does not work no lights, no power, nada. It was originally my dads when he finished putting together his truck he was going to use it. But when he was connecting it he told me it started getting very hot in the back and he disconnected it. When it was connected I went over all the power wiring it was all correct. Also checked the battery voltage it was at 12 volts with the truck off. Cd player was last working last summer.
Is it worth repairing? It was a good deck when it was last working. Any ideas what could have burnt on it?
Feel the PUNCH
Old 22nd June 2012, 03:25 PM   #2
Perry Babin is offline Perry Babin  United States
If the back (heatsink) of the head unit got hot, it may have a defective speaker output IC or there may be a shorted speaker wire.
Old 22nd June 2012, 03:36 PM   #3
Yes the back would get hot where the IC is at. Could this be why it won't work? Only thing it will do is eject the cd out but no lights on the faceplate.
Feel the PUNCH
Old 22nd June 2012, 10:40 PM   #4
It may have other problems. A defective amplifier IC won't generally prevent it from working unless it's causing it to blow fuses. I'm assuming that you confirmed that you had 12v both power wires where they go into the head unit?
Old 23rd June 2012, 03:46 AM   #5
No fuses blow when I put power to it. It doesn't get hot when it's connected to my 10 amp power supply. And yes I checked all wires and voltages.
This head unit doesn't have a fuse on board or not that I know of...
Feel the PUNCH
Old 24th June 2012, 01:53 PM   #6
Did you check the voltage going into the plug on the back of the head unit (at the head unit) to confirm that you had 12v on both the constant and ignition wires?
Old 9th June 2013, 03:48 PM   #7
Kip McGee is offline Kip McGee  United States
Perry that sounds right. If you do not want to fix it for him I would do it for $75.00
Kip 601 325 0464. If it is the Amplifier IC and an open trace.
I have seen these units draw so much current that a trace on the board will open.
Rockford fosgate deck! Anyone repair these?Hide this!Advertise here!
Rockford Fosgate P800.2 [Repair] woutzor Car Audio 98 7th November 2014 09:12 PM
Need repair for a Rockford Fosgate Punch 600a5 ChiefWBLeo Car Audio 4 5th March 2012 03:01 PM
Rockford fosgate punch 125.2 repair help chipper Car Audio 9 25th February 2012 04:31 PM
repair of rockford fosgate power 451s chemid51 Car Audio 10 26th December 2009 08:34 AM
Repair of Rockford Fosgate Punch 201s Jackson75 Car Audio 15 3rd November 2009 10:34 PM
Copyright ©1999-2017 diyAudio
