Need help! Hifonics Brutus bxi 2010D 2000 Watt Amp! - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 21st June 2012, 11:27 PM   #1
Default Need help! Hifonics Brutus bxi 2010D 2000 Watt Amp!
I am trying to pull the whole board out the housing. But i can't seem to get these black clips off. Does anyone have an idea how to do it?
photo by ZarazuaT, on Flickr
Old 22nd June 2012, 12:25 AM   #2
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 22nd June 2012, 12:34 AM   #3
Mine must have been glued in or something cuz i broke it off and it sparked a little bit.
photo-2 by ZarazuaT, on Flickr
photo-1 by ZarazuaT, on Flickr
Old 22nd June 2012, 04:11 AM   #4
It might be a harder but they should slide sideways. Get them to an open spot and remove. I have had to do this on a poweracustic once.
Old 22nd June 2012, 08:30 AM   #5
They don't slide They are on there pretty good....
Old 22nd June 2012, 09:04 AM   #6
You need to work side to side. Place the pliers as pictured, then give it a slight twist one way and pry. Move back the other way and pry. Keep doing this, it will pop.
Old 13th September 2012, 05:45 PM   #7
Default Desmontar clips de los transistors
Tengo un Hifonics BX1 1606D con el mismo problema: quitar los clips sin dañaralgo. Mi prgunta es si se jalan hacia arriba o se deslizan hacia un costado hasta salir de las ranuras. gracias. Danchip399
*Google translation added by Moderator:
I have a Hifonics 1606D BX1 with the same problem: remove the clips without dañaralgo. My PrGunTa is if you pull up or slide to the side to get out of the slots. thanks
Old 13th September 2012, 06:23 PM   #8
Speakerholic
Cal Weldon's Avatar
This is an English speaking forum. If you wish to post in another language please translate to English as well.
Thank you.
Este es un foro de habla Inglés. Si desea publicar en otro idioma, por favor traducir al inglés también.
Gracias.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 4th November 2012, 01:48 AM   #9
Anyone Looking for replacements ---> Mouser Electronics - Catalog Viewer
Old 15th January 2013, 08:31 PM   #10
angel88 is offline angel88  Mexico
I have a Hifonics brutus bxi2008d but 70n06 burned transistors and the change did not realize that one was different and 65n06 aora was not where I will allude aguien please
Hifonics Brutus BXi 2608D Dr Zeus Car Audio 8 18th December 2016 08:11 PM
hifonics bxi 2000 brutus timwebb Car Audio 3 7th May 2012 05:06 AM
Hifonics Brutus BXI 2008D mike49504 Car Audio 13 17th February 2012 05:21 AM
2600 bxi brutus timwebb Car Audio 40 1st January 2011 08:32 PM
Hifonics Brutus BXi 1606d parts Bertje Car Audio 2 3rd June 2010 04:33 PM
Copyright ©1999-2017 diyAudio
