Difference on Dot found on the middle and leftmost
Old 21st June 2012, 12:49 AM   #1
nonprof is offline nonprof
Default Difference on Dot found on the middle and leftmost
I have a 70N06 MOSFET transistor which the DOT mark is at left/right most. But commonly MOSFET mark dots found on the middle, what is the difference between them? are they interchangeable replacement?
thanks you!!!
Old 21st June 2012, 01:15 AM   #2
brandes.cm is offline brandes.cm  United States
Maybe the mold used to form the plastic around the die, the injection point is centered on some and not on others. The dot should have no meaning at all.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Difference on Dot found on the middle and leftmostHide this!Advertise here!
ZRT in the middle (center) MMeche Multi-Way 5 24th January 2011 06:01 PM
Greetings from the middle of Kansas! Brion55 Introductions 1 25th June 2005 04:59 PM
hello from the middle of canada... lumberdust Introductions 1 22nd June 2004 11:15 PM
What to use in the middle? Duck-Twacy Multi-Way 13 7th October 2003 05:35 AM
