Go Back   Home > Forums > General Interest > Car Audio
Old 9th September 2012, 04:45 AM   #41
If the drive circuit is producing a clean square wave, it's likely something beyond the driver board. Since this test uses a low frequency signal for testing, it's not definitive because the driver IC could be OK at low frequencies but not at the higher frequencies that are involved with the normal operation of the class D amp circuit.
To test the drive at higher frequencies, you'd have to inject a higher frequency signal into the 2113 but I've never had to do it on this board.
It's also possible that the circuit producing the high-side drive circuit supply voltage isn't working but that's not likely.
It's possible that there are leaky or weak drivers. To test them in the circuit, you'd have to find a way to break the connection to the output gate resistors so that they wouldn't not be driven. Then test as you did previously. Loading them with a 470-1k ohm resistor would make it more obvious if one was defective.
Old 10th December 2012, 02:31 AM   #42
Just to bring closure to this thread.
RA1 was open, a 2.2ohm resistor in the feedback loop. The amp would idle fine with no signal, once applied the amp would produce audio for a split second and current would spike. It would continue this cycle until the audio signal was removed.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 11th April 2013, 01:19 AM   #43
Dear friend
i need to quotation
DML4000 50PSC
THANKS
David
Powerbass ASA1500.1Dx brandes.cm Car Audio 19 11th May 2012 03:48 AM
DLM4000 class D driver board pergo Car Audio 20 6th March 2012 08:35 AM
Powerbass ASA1500.1Dx Dr Zeus Car Audio 11 26th November 2011 11:43 AM
PowerBass ASA-600.4 audiobahnkid592 Car Audio 3 19th May 2010 09:12 PM
Powerbass thunderlaxton32 Car Audio 1 27th September 2007 01:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
