Powerbass xa3000/DLM4000 driver
Old 8th September 2012, 08:08 PM   #31
timwebb is offline timwebb  United States
i got one if u need any reading off it. and are your gate resistors 100ohms?
Old 8th September 2012, 08:45 PM   #32
Perry Babin is offline Perry Babin  United States
Which transistors are getting hot when it begins to draw excessive current.
Old 9th September 2012, 12:13 AM   #33
brandes.cm is offline brandes.cm  United States
The output fets with the drain(second leg) tied to +rail.
Labeled M10, M4, M3, M2, M1
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 9th September 2012, 02:47 AM   #34
Set-up your scope in differential mode and look at the drive signal. Does it swing approximately 10v and is the falling side a perfect vertical line down to about 1v?
With the scope in normal mode, does the gate swing to about 10v over the rail voltage on the drain?
Old 9th September 2012, 02:58 AM   #35
I get no oscillation unless I drive a signal in, in that scenario the amp will only flash a gate signal shortly before drawing current and going back to idle.
Old 9th September 2012, 03:09 AM   #36
When you were working on it previously it was producing drive and driving the outputs. What changed?
Old 9th September 2012, 03:18 AM   #37
Not sure, since I got back to this amp I need to drive a signal in order to see a gate drive.
This amp should self oscillate without a signal?
Old 9th September 2012, 03:39 AM   #38
Some self oscillating amps require a signal to make them start oscillating. This varies from one amp to another, even among those of the same model.
I'd suggest removing the 4 driver transistors and driving a strong signal into it to see if you have drive to both sets of driver transistors. The drive signal will be a square wave of the same frequency as the drive signal. I'm not sure whether you'll have a drive signal on the high-side because it may need oscillation to produce the high-side driver supply voltage.
If there is insufficient DC voltage measured directly across VS and VB on the driver IC, you can supply it with a 9v battery. If the SMD electrolytic capacitor is connected to those pins, connect the 9v battery there. Be sure to get the positive/negative right. Make sure that the 9v battery isn't getting hot while testing. Disconnect the battery when not performing tests.
Before applying power, confirm that you read 47k ohms between the gate and source for the outputs.
Old 9th September 2012, 04:44 AM   #39
Low side square wave is on riding on -rail and the high side appears when I apply the 9V battery for the supply.
So it seems the drive circuitry is operational, does that leave a leaky drive transistor. They measure ok off the board. JE172 and JE182 are the parts used.
Old 9th September 2012, 05:38 AM   #40
I put the drivers back in and now I get nothing. When I touch my scope probe to the low side gate resistors the amp draws serious current.
Powerbass xa3000/DLM4000 driverHide this!Advertise here!
DLM4000 class D driver board pergo Car Audio 24 17th October 2017 04:13 AM
Powerbass ASA1500.1Dx brandes.cm Car Audio 19 11th May 2012 04:48 AM
Powerbass ASA1500.1Dx Dr Zeus Car Audio 11 26th November 2011 12:43 PM
PowerBass ASA-600.4 audiobahnkid592 Car Audio 3 19th May 2010 10:12 PM
Powerbass thunderlaxton32 Car Audio 1 27th September 2007 02:26 PM
