Powerbass xa3000/DLM4000 driver - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 24th June 2012, 05:48 PM   #11
The current spikes before it trips. If I let it idle with a small input signal the current slowly climbs, then it spikes and goes into protect.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 24th June 2012, 06:24 PM   #12
Does one group of FETs get hot when this happens?
Is it possibly shutting down because the voltage at the B+ terminals drops as the current increases?
Old 24th June 2012, 06:49 PM   #13
No outputs get hot, the supply doesn't dip.
I don't see the square wave any more on the outputs.
I'm thinking a gnd issue, maybe.
Old 24th June 2012, 06:51 PM   #14
This has dual TL494 ic's, apparently one for each supply.
Old 24th June 2012, 07:01 PM   #15
The "SPT" line is going high during protect, not sure what that stands for.
Old 24th June 2012, 07:04 PM   #16
One is for the rail supply and the other for the low voltage supply. The two larger transformers have only a single secondary winding. They work together to act as one transformer.
If the outputs aren't getting hot, the problem is likely in the power supply but I don't know of anything that would cause the amp to go into protect due to a problem in the power supply.
The transformers in these amps have a problem shorting where the terminal windings rub on the other windings. Move the secondary terminal windings to see if it makes a difference.
Old 24th June 2012, 11:34 PM   #17
If I measure resistance from signal gnd to rectifier gnd, reads 0.2 ohms. Read from speaker neg to rectifier gnd, reads .25 ohms. The only time I see a high frequency square wave is when I reference rectifier gnd. It measures ~25Khz, is my scope playing tricks?
I lifted the diode that was causing the protect.
Old 25th June 2012, 12:13 AM   #18
So the high side fets have a square wave on the gate, really faint. The low side I see no activity and the fets stay cool. The current will spike every 10 seconds like its trying to output.
I replaced the IR2110 on the driver board and put the diode back in place. It no longer goes into protect.
Old 25th June 2012, 12:35 AM   #19
Rectifier ground = secondary ground?
What's the resistance between the secondary ground and the primary ground (no RCAs plugged in)?
Old 25th June 2012, 12:43 AM   #20
985 ohms
DLM4000 class D driver board pergo Car Audio 23 17th January 2017 03:48 AM
Powerbass ASA1500.1Dx brandes.cm Car Audio 19 11th May 2012 03:48 AM
Powerbass ASA1500.1Dx Dr Zeus Car Audio 11 26th November 2011 11:43 AM
PowerBass ASA-600.4 audiobahnkid592 Car Audio 3 19th May 2010 09:12 PM
Powerbass thunderlaxton32 Car Audio 1 27th September 2007 01:26 PM
Copyright 1999-2017 diyAudio
