Hifonics HFI2000D goes to protect
Old 20th June 2012, 01:42 AM   #11
timwebb is offline timwebb  United States
i worked on that board. the output fets were bad but they all tested good. is the power supply functiong?
Old 20th June 2012, 01:52 AM   #12
brandes.cm is offline brandes.cm  United States
Pin 3 of the comparator is high, which leads me to believe something is messed up in the outputs or protect circuit.
The supply won't run in this state.
BK 1544 40Mhz scope.....Pyramid PS-26KX supply.....Tenma 72-380 Func. Generator
Old 20th June 2012, 01:53 AM   #13
Perry Babin is offline Perry Babin  United States
Post the DC voltage on the comparator.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 20th June 2012, 01:56 AM   #14
Pin 1: 6.94
Pin 2: 2.5
Pin 3: 9.98
Pin 4: 0.00
Pin 5: 1.036
Pin 6: 3.009
Pin 7: .113
Pin 8:13.25
Old 20th June 2012, 02:37 AM   #15
With pin 3 at 10V, it seems D29 is not functional. It is a 5.6V zener.
Old 20th June 2012, 03:23 AM   #16
I have been referencing the AQ2200 schematic, reference designators are the same for the given part.
Zener is fine.
D206
K: 0.00V
A: ~12.5V
D12
K: ~3.25V
A: ~12.5V
Old 20th June 2012, 07:36 AM   #17
It appears that there are multiple problems. What happens if you pull Q226?
If the voltages above for the diodes are with the diodes in the circuit, the diodes are defective.
Old 20th June 2012, 10:56 AM   #18
Zener is fine.
D206
K: 0.00V
A: ~12.5V
D12
K: ~3.25V
A: ~12.5V
I put them down wrong, should read:
D206
K: ~12.5v
A: 0.00v
D12
K: ~12.5v
A: ~3.25v
Old 20th June 2012, 05:29 PM   #19
Hifonics HFI2000D goes to protectHide this!Advertise here!
Hifonics Zeus VIII stuck in protect mbates14 Car Audio 11 16th May 2012 01:36 AM
Hifonics BXi2006d not coming out of protect. Any advice? RRR37 Class D 7 6th July 2011 03:35 AM
amp goes to protect, why? eeyore757 Subwoofers 6 21st March 2007 11:29 PM
