Go Back   Home > Forums > General Interest > Car Audio
Old 6th September 2012, 10:11 PM   #11
I've marked x's on the packages that get hot.
Old 6th September 2012, 11:16 PM   #12
There are 3 outputs grouped together but only one has an x on it. Remove it and clean the pads to ensure that there are no solder bridges. Does that change anything?
Old 10th September 2012, 10:31 PM   #13
I don't understand what you mean with the 3 outputs. It seems like the output(yellow wire) is connected to a group of 6 TO-220 packages(top left of picture). Can you further describe which package you are talking abot?
Old 11th September 2012, 10:51 AM   #14
There is a group of 6 outputs for one channel. There are two groups of 3 for that channel. One group of 3 had 3 Xs. The other group of 3 has 1 X. Remove the transistor with the X in that group of 3.
Old 12th September 2012, 01:56 PM   #15
That does seem to be the issue. Before removing the component I measured resistance to be ~200 ohms between pins 2 and 3. After removing it went up to Mohms.
I'm looking to find out what the part number is. The numbers are not legible, but it looks like 2N6438. I can only find that part as a TO-3, so it doesn't look like I'm able to read the part number well enough. How can I go about finding the part number, or selecting an appropriate alternate?
Old 13th September 2012, 05:44 AM   #16
2N6488. They have to be replaced in groups.
Old 13th September 2012, 01:20 PM   #17
Thank you Perry. By the way I did go ahead an turn on the amp(no load) to ensure the short was fixed and both channels now draw standby current of ~.8A.
I'll go ahead and replace all 6. Should I also be replacing the complementary 2N6490s or is it only important to change the ones in parallel with each other?
Old 13th September 2012, 01:47 PM   #18
If you want the amp to be as reliable as possible, replace the 2N6491s also.
Old 13th September 2012, 07:09 PM   #19
Great. Thank you again Perry, you've been a huge help.
I'll confirm all is well once I get these components in and test the amp.
Old 10th October 2012, 10:51 PM   #20
I tested the amp and after about 15 seconds on I heard a noise and smelled some smoke. I turned it off quickly, but now when I turn it on it draws ~15A (current limited on my power supply).
I am trying to trace the problem and I've found that there is no voltage on one of the inputs to the transformer, so I suppose it's the drive circuitry, but I am unsure how this amp is laid out. What components should I be look at or what tests should I perform?
LM3886 based 8 Channel amps for linkwitz Orion ST7677 Chip Amps 161 31st July 2012 03:24 PM
Orion 2350gx right channel not developing full power SomeGuyInPDX Car Audio 4 3rd November 2011 03:09 PM
Orion Cobalt 304, 1 channel not working ash4kel Car Audio 10 29th March 2011 10:44 PM
12 Channel Amp - perefect for active projects like the Orion mbcouple Swap Meet 1 5th November 2008 01:24 PM
8 Channel Amplifier for Linkwitz Orion Kit ngiachin Chip Amps 12 9th July 2004 08:13 PM
Copyright ©1999-2013 diyAudio
