Rockfordfosgate Pump 600.4 accident - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 12th June 2012, 03:29 PM   #1
larz is offline larz  Philippines
Default Rockfordfosgate Pump 600.4 accident
good day guys!
i have a RF fosgate pump 600.4 when i,m resoldering some parts in the board i accidentally shorted the FET pins(no B+/power applied)made contact w/ the soldering tip. when i turn it on there's no power! do i damage the fet? possible damage? i really need your help guys feel really very bad of happened.
unfortunately i dont have a schematic diagram.
Old 12th June 2012, 05:40 PM   #2
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
May be a charged cap. I work repairing variety of electronics, and I had a lamp (220V 150W) with a piece of wire and a crocodile clips, and short all HV caps before working in the set. Sometimes they have large resistors, so the discharge time is very large, and dangerous. In this way, not only discharge them quickly, also I view when them are discharged (Lamps dims quickly).
Replace the part, and check parts surrounding it.
Good Luck.
If anything can go wrong, it will.
If anything just cannot go wrong, it will anyway.
Old 13th June 2012, 05:58 AM   #3
Good Luck.
thanks for the tips very much appreciated
Old 13th June 2012, 06:18 AM   #4
sir Perry Babin i hope you read my post f you dont mind. i need your help tips where do i start to dig. you are one of the great wizard in here.
thanks sir.
i am an experienced in electronics but not so familiar in mosfets.
what are the possible damage i've done? do i engage the protect mode?
I NEED MORE INPUTS GUY
thanks.
Old 13th June 2012, 07:08 AM   #5
You need to determine whether there are any defective transistors. Just because there was a spark doesn't mean that it caused damage.
Old 13th June 2012, 07:32 AM   #6
i hope nothing happens on that spark( i think capacitor discharge)...
you mean the power output transistors?
ok i will check all of them.
i hate double sided board w/ surface mount parts its very time consuming
specially if you don't have the ace(schematic) hehe
by the way thanks a lot for the reply sir
i will let you know the progress
Use of Tango NN-600-600 Transformers ? HP8903B Tubes / Valves 12 6th October 2014 09:49 AM
FS cinemag transformers nickel CMOQ-2H 600:600 Gluca Swap Meet 10 6th March 2013 07:01 PM
NAD T734 accident bubbakittee Chip Amps 4 15th October 2008 10:22 AM
WTB: 600/600 line out trannys mobyd Swap Meet 0 13th February 2006 07:30 PM
unfotunate accident JOE DIRT® The Lounge 10 3rd July 2003 03:11 AM
Copyright ©1999-2017 diyAudio
