diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   diamond d6 1500 (http://www.diyaudio.com/forums/car-audio/213846-diamond-d6-1500-a.html)
timwebb 3rd June 2012 11:44 PM
diamond d6 1500
this amp is pulling current. the power supply was cooked. i used 47ohm resistors and irfz44. in the power supply. i removed the driver card and all output transistors. and still no luck.
Perry Babin 4th June 2012 02:47 AM
Do you have a clean drive signal on the gates of the power supply FETs?
timwebb 4th June 2012 03:34 AM
yes i have a clean square wave and 4 volts at the gate.
Perry Babin 4th June 2012 04:04 AM
Did you remove the rectifiers to see if that eliminated the excessive current draw?
timwebb 4th June 2012 07:34 AM
it powers up fine with them removed. it has to be in the output section..
Perry Babin 4th June 2012 07:50 AM
Are the rectifiers shorted?
Are they in the correct locations?
Resources saved on this page: MySQL 18.75%
