SPL Dynamics S-4002 - Output shorted and power half dead - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 2nd June 2012, 06:48 PM   #1
mns80 is offline mns80  Finland
Default SPL Dynamics S-4002 - Output shorted and power half dead
This is the second time I have the amplifier open and messing around with it.
First time was for fun, wanted to know if I were able to get it working. As the owner, a friend of mine, said that he tested with a very weak battery and nothing happened I applied some power to it to test if anything happened. This resulted in a cracked FET in the power section and a small fire. Some measurements later, one output transistor and the blown fet. Ordered some new parts soldered in and applied some power again. No smoke nothing but DC on the output. More measurements and the conclusion was a shorted Zener in the regulator for the preamp section. replaced it and Amp was working fine with sound and all. Installed in car to test with some more power and it worked fine one and a half day. Everyone was happy until it suddenly was silent again.
No is the second time I have it open. Same bank output transistors shorted, however I did not apply any power this time to blow something up. After some desoldering I applied power to see if power supply was in order, nonono, one toroid is not giving voltage, same side as the output and same as where the fet blew last time. All four fets in the power section look kind of strange on the back, like the metal has almost melted in one spot. These are FQP50N06.
Can anyone suggest what to do with this amp, will it again work one and a half day again if I replace the same parts or is there something else I should consider too?
Please note that I am sort of a noob with amp repair.
/Mats
Old 4th June 2012, 03:07 AM   #2
All power supply FETs in the failed supply have to be replaced at once. You must confirm that all gate resistors are within tolerance. You also have to confirm that you have a good drive signal. If the gate signal isn't as is should be, you need to check the driver transistors.
Post a photo of the board in the amp if you can't repair it so we can see what you have.
SPL Dynamics S-2000D ultra Car Audio 18 18th November 2013 07:25 PM
Balancing between dynamics and bass depth in moderate SPL levels alspe Multi-Way 8 9th September 2011 05:17 PM
Damn SPL Dynamics amp dead after shock! Custom Chris Car Audio 23 18th May 2011 08:09 AM
SPL Dynamics D6 Schematic Wanted mischka Class D 0 17th September 2009 06:18 PM
Copyright 1999-2017 diyAudio
